Apple Wireless Keyboard Logo
Posted on Dec 25, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Where can I find the @ key on an Apple Wireless Keyboard. It is marked on the g-key, but it results in a similar looking output, but certainly not the @ key.
Anonymous
Level 3:
  • Master 600 Answers
  • Posted on Jan 11, 2011
Anonymous
Master
Level 3:
Answers
600
Questions
Helped
282411
Points
1231
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 5 Answers
  • Posted on Nov 27, 2012
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
5
Questions
0
Helped
819
Points
6
You are typing on a keyboard made for typing Swiss German; that means the writings on the keys match what you get on the screen only if you activate the Swiss German keyboard layout.
You probably see a flag in the menu bar, indicating which layout is currently active. By clicking on it, you can switch to another layout or show the "Onscreen keyboard". To find on which keys are the various special characters, look at the onscreen keyboard while you play with the Option and Shift keys. Orange keys are special: they give access to a whole "family" of accented characters, e.g. Option-e puts an acute accent over the letter typed after it.
1helpful
I have an emachine newer one cant seem to turn on wireless switch so i can connect to wifi
Look for a wireless icon similar to the attached picture on the keyboard, it locates usually among F1 to F12 keys, if you don't see anything similar from F1 to F12, then try looking from 1 to 9 keys. Once it's located, press and hold down the Fn key on the keyboard and press the key with the icon (i.e. wireless icon) simultaneously for a couple of seconds, this will turn on and off the wireless function of your system. Let me know if you need further help with the model number of your emachine. Good Luck.
1helpful
Wireless on my compaq c60 is disabled but i cant find a switch to enable it. Can i use function keys and if so which?
I am unable to find a photo of your laptop's keyboard, so I cannot be certain which function key will enable your wireless adapter.
However, most laptops are very similar, so this solution should work for your problem.
1) Locate the secondary function key (probably labeled "FN") on your keyboard.
2) Locate the key which controls your wireless adapter as a secondary function. It will have the following image on the key: http://cdnsupport.gateway.com/s/Mobile/2007/Phantom/WirelessIcon.gif
3) While holding the FN key, press the wireless key
4) Your wireless adapter is now enabled. If you are still having wireless issues, the problem was not that the hardware wireless adapter was disabled.
2answers
My keyboard is not responding to all characters when I type and I have to continually press some keys to get a result
Sometimes you may find certain keys of your laptop keyboard not working properly. You type those keys but there is no output on the screen or you need to press these keys firmly to get a result. You face this problem if you accidentally spill any liquid substance on your keyboard, or due to dust accumulating on the inside of the keys, pressing certain keys really hard while playing games or even due to absence of lubrication. Therefore you are suppose to maintain your laptop keyboard by cleaning and lubricating it regularly.
INSTRUCTIONS
  1. To start with, take out each key out from the laptop keyboard. Use a small screwdriver to carefully pry each key by making it loose. As they become loose, keys will simply pop off. Also, take out the rubber piece present under every key. Keep the keys and rubber pieces in different containers.
  2. Once you have removed all keys from the keyboard, you will have to clean the keyboard from the inside. Use cotton swabs or ear bubs and slightly dip them in water. Avoid getting them too moist, as excess water can damage the keyboard. Meticulously clean the whole keyboard using moist cotton swabs, laying extra emphasis on key spaces.
  3. Now, start cleaning keys you had earlier removed and kept in the container. Use foam rubber and lighter fluid to clean each key alone. This will help in removing any sticky substance present on keys. Apply any household cleaner on these keys and let them stay for about 15 minutes. After this, wash all the keys properly using hot water and let the keys dry completely.
  4. The small rubber pieces which you took out earlier and kept in the container have to be thoroughly rinsed in warm water, after you have sprayed a household cleaner on them. Soak these rubber pieces up in paper napkins so that they dry quickly.
  5. To lubricate the keys, place all keys (facing top-down) on a flat surface. Apply mild lubricant from all sides, on all keys and leave them to dry. Avoid applying too much lubricant instead go for a light coat.
  6. Similar to the manner in which you lubricated the keys, apply mild lubricant on the keyboard surface and let it dry.
  7. Once you have cleaned and lubricated all the parts, carefully reassemble the laptop keyboard. Begin with placing all rubber components on the keyboard. Next, fix all keys in their respective positions cautiously securing the wire in these keys. Use your finger and press down all keys, one at a time, firmly so that they fit properly in the slots. That is it.
  8. goodluck
I lost my question mark -- what do I press to get it back
Press your FN key.
If you look at your Keyboard on a laptop you'll see that certain keys have more than 1 symbol on them.
The FN key brings these secondary symbols to life as live keys and pressing it again will restore original function to the keyboard.
Apple wireless keybaord function keys on top dont respond to volume up or down
Go to your system preferences. You go to the upper left hand corner click the apple and go to system preferences. Click the keyboard settings. Make sure that "Use all F1, F2, etc. as function keys is not checked off
Apple wireless keyboard. the keys hard to press and it feels sticky. What can I do to get rid of sticky keys.
Sorry to read about your problem, I hope this helps you out.
your keyboard got wet by a drink..nothing you can do, except buy a new keyboard.
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
My Fujitsu Siemans Amilo Li1718 has overheated
Hi. Yes it almost certainly has a power stage fault and will probably toast a new keyboard. Needs to be looked at by a tech I'd say.
Mark
Top Apple Computers & Internet Experts
Paul Carew
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
