Question about Dacor Ovens
My dacor oven light won't go off & the error message says close the door but the oven door is already closed. this is occurring only in the top oven.
Posted by lghirardo on
Barrett Palumbo
  • 1,772 Answers
Sorry to read about your problem, I hope this helps you out.
you have a defective door switch
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
Posted on Dec 25, 2010
Anonymous
    Problem Solver:
  • 15 Answers
It sounds to me like u have one of the really fancy Dacor EO, MOV, MOH or PO oven models. All these use sensors instead of door switches and it looks like there's a bad sensor or it just out of position.
Posted on Jan 12, 2011
My ge double oven326b1230p001 the top door is not closing properly and the light keep on,please advise how to close top door
Oven Range Door DIY Repair - YouTube
? 2:50
www.youtube.com/watch?v=6YFTYWsiO1M
Jan 22, 2011 - Uploaded by ApplianceAdvice Watch Queue. TV Queue. __count__/__total__. Find out why.Close ... This video explains how to remove an oven door on many higher end ovens, such as GE, Kitchen Aid, Kenmore, Whilrpool, Dacor, ... Top comments ... fell off and the screws fell down into the oven door and I did not know how to fix it.
Aug 08, 2015 | GE Ovens
The oven door will not close .
i just had a similar problem .the door would fall and i had to lift the top of my door hinge to close it .I found that the pin on the door hinge spring had fall.en out . I installed it back and now it works the way it should.the spring should feel tight with no movement.
Mar 25, 2014 | Dacor MCS130 Millennia Electric Single...
Dacor wall oven model# MCS130S door won't close.
sorry this is a common fault with them you cant fix it i have tryed in the passed
Oct 15, 2012 | Dacor MCS130 Millennia Electric Single...
Oven door won't close.
sorry i have tryed to fix them in the passed they cant be fixed need a new door sorry
Oct 15, 2012 | Dacor MCS130SS Millennia Electric Single...
Door won't lock for self cleaning although closed
Hi, Look to see if the safety switches in the slots in the door is bent Kind of hard to figure out if you don't know how they are supposed to look like but guess remember it's not working either, also could be a bad switch itself.
Nov 22, 2011 | GE Profile JTP56 Electric Double Oven
Eog 6330 oven door does not fully close ie small gap at top unless you hold door closed are hinges damaged or bent?
you will have to replace both left & right hinges / this should correct problem .. mm
Jul 12, 2010 | Electrolux Ovens
Oven door isn't closed tightly on both sides.
If it is a door that lifts up and down, then the only solution is to replace both door hinges, as they are not normally adjustable, it is the springs that are weak.
Plz rate my solution.
Thanks.
Jan 05, 2009 | Dacor ECS130 Epicure Electric Single Oven
Faulty oven door
This IS SO EASY !! I have the DACOR 48...no tools, 5 minutes and you are done! It took me 8 years of frustration and I fixed it TODAY !!
Just open the door, latch the small hook that binds the two hinges together. Next try to slowly close the door until resistance. Just when you think you might break something push up another 2 inches. Now lower the door , unhook the latch to seperate the hinges (latches) nad PRESTO a snug fit !!
Dec 19, 2007 | Dacor ECS127 Epicure Stainless Steel...
Ovens Logo
308 people viewed this question
Top Dacor Ovens Experts
Paul Bade
Vincent G
Vincent G
ray gallant
Are you a Dacor Oven Expert? Answer questions, earn points and help others
