Question about Casio G-Shock GW300CA-1V Wrist Watch
I have problem with backlight. first it work normaly but after it did not work. maybe it is switch of. i have not user manual. second problem is that i do not hear signal. I have casio g 7302Rl
  • 577 Answers
Hi,you need to look at the user manual..
just in case ,if you need soft version of the user manual pls visit the URL below..
Hope this helps! Take care and please Remember to rate/vote and give me
4 Thumbs Up for me to continue for Helping out the Community :)
Thanks
CASIO Watch User Manual Archives
http://world.casio.com/wat/download/en/manual/
Use this page to download a copy of CASIO watch manuals in PDF format.
To download a PDF file, enter the four-digit (or three-digit) module number marked on the back cover of your watch.
Posted on Jul 02, 2011
6ya staff
SOURCE:
How do I switch from a 24 hour scheme to 12-hour scheme?
Firstly, check user manual. Secondly, search online by "make & model +instructions"
Jul 10, 2015 | Watches
Cant set it
    Setting the Time
  1. G-Shock watches feature a digital display that is set using the function buttons on the outside of the watch face. To set the time, press and hold the the upper left button until the seconds unit blinks on the display. Reset the seconds to "00" by pressing the lower right button.
    Push the lower left button to switch to the hours unit, which will start blinking. Advance the hour by pressing the lower right button. If you hold down the lower right button, it will advance the hour unit at a higher rate of speed. Once the hour is set, press the lower left button to switch to the minutes unit. As with the hours unit, pressing the lower right button will advance the minutes and holding it down will advance the minutes rapidly.
    Once the time is set, press the upper left button to save the setting.
  2. Backlight
  3. The backlight on a G-Shock watch has a manual control and an automatic function that will light the face of the watch whenever the alarm, countdown alarm or hourly alarm ring. To use the manual backlight, press the button on the bottom of timepiece. The light will glow for approximately 2 seconds before going out.
    The automatic function is set by pressing and holding the lower right button. When the automatic function is set, an indicator icon will display on the watch face above the seconds unit. You can turn off the automatic backlight function by pressing and holding the lower right button until the icon disappears.
    Note that backlight causes a drain on the battery, and overuse of the backlight will greatly reduce battery life.
  4. Setting the Alarm
  5. The G-Shock has an alarm that emits an audible tone for approximately 20 seconds when it turns on. To set the alarm, press the lower left button until "AL" displays in the upper left corner of the timepiece. Press and hold the upper left button until the hours unit starts to blink. Adjust the hour by pressing the lower right button. As when setting the time, you can advance the hour at a higher rate of speed by holding down the lower right button.
    Once the hour unit is set, press the lower left button to advance to the minutes. Use the lower right button to set the minutes. Follow these same instructions to set the month and day you want the alarm set.
    When the alarm time and date are entered, press the upper left button to save the setting. Push the lower left button three times to return the G-Shock to "Timekeeping" mode.
Aug 19, 2010 | Casio G-Shock G 520D 4AVDR Cockpit Series...
I cant figure out how to work it my casio gshock
    Setting the Time
  2. Backlight
Aug 14, 2010 | Casio Watches
Stopping after 12 or 24 hours
Read your manual carefully and you will notice that the big, tall seconds hand is part of chronograph function. So, by pushing upper button you are actually engaging chronograph. This puts more strain on movement gears and consumes more battery power. When your watch is in normal timekeeping mode, the small seconds hand is counting seconds, not the big one which should be steady pointed at 12. I would recommend to put a new battery in your watch, reset it and start using it as described in users manual. You can download users manual here: http://www.oakley.com/customer-care/support/watches
Rate me, plz.
Jan 10, 2010 | Oakley Detonator OAK0530 Wrist Watch
Just got a nike anvil comold but cant get the backlight to work
I had the same problem. The seller told me to reset the watch by pressing down on all four buttons at once. Sure enough, the backlight function was enabled again.
Feb 14, 2009 | Nike WR0099 017 Mettle Anvil Comold Super...
Strange symbol
The same thing happened to me, and here is what I found in an online user manual (but not the one delivered with my watch). Switching the Backlight On
Press the Light button and the display is illuminated for a few seconds.
After you have illuminated the display once while exercising night mode symbol (MY WORDS HERE : the "eye symbol") appears in the display. The display automatically illuminates each time you press any button or bring the wrist unit near the Polar logo on the transmitter, until you stop recording the exercise.
Sep 16, 2008 | Polar F6 Wrist Watch
Backlight
Try holding the indiglo button for atleast 3 seconds.
Sep 02, 2007 | Fossil Philippe Starck PH1035 Wrist Watch
Backlight doesn't work
Go to this link; http://world.casio.com/wat/download/en/manual/ and enter the four digit code on the back of the watch, you should get a user manual - i do think you are probably right however. Hope this helps :)
Apr 18, 2007 | Casio G-Shock GW300A-2V Wrist Watch
Casio G-Shock GW300CA-1V Wrist Watch Logo
267 people viewed this question
Top Casio Watches Experts
Janelle Schoonover
Janelle Schoonover
Ekse
k24674
Are you a Casio Watch Expert? Answer questions, earn points and help others
