Question about SanDisk Sansa e250 MP3 Player
Hello excactly on christmas day my sansa e250 stoped responding, it turns on but it does not move on to the home page of the player, the screen stays at the sandisk screen, then it fades for about 2 seconds then it returns to the sandisk screen. what can do with my sandisk?
Posted by m_j_gamer211 on
John Fourteen Six
  • 2,418 Answers
Try to do a reset, follow these instructions if this does not work. Reseat the battery.
Resetting your player: 1. Press and hold the Power/Menu button for approximately 20 seconds. 2. Release the Power/Menu button. 3. Press the Power/Menu button again to turn on the player.
Resetting a Sansa View, Fuze, or Clip player: 1. Slide and hold the Power switch up for approximately 20 seconds. 2. Release the Power switch. 3. To turn the player on, slide the Power switch up then release instantly.
Posted on Dec 25, 2010
My mp3 player is frozen as soon as i turn it on it just come on and say V4.0.44A SANSA M240 1.0GB and thats it it won;t play or nothing. and its been like this for a long time.
All Answers page from Sandisk for the M240:
http://kb.sandisk.com/app/answers/list/kw/m240/r_id/101834/sno/1/search/1/session/L3NpZC9JeGphOWVOag%3D%3D#s=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
Looking for answer 34, when the player is not turning on:
Trying to reset performing the actions in solution 1. Next, when still not responding solution 2:
http://kb.sandisk.com/app/answers/detail/a_id/1115
Looking for answer 14, when the player freezes. Telling to format the player. Follow up the instructions on next page:
http://kb.sandisk.com/app/answers/detail/a_id/1/p/555%2C662%2C670%2C674/page/2/r_id/101834
Sometimes a firmware update or reinstall is needed to have the player function normally again. See next page how to install and use the Sansa firmware updater:
http://kb.sandisk.com/app/answers/detail/a_id/1107/kw/firmware/p/555%2C662%2C670%2C674/r_id/101834
Manual for the M200 series in pdf format:
http://mp3support.sandisk.com/downloads/um/sansa-m200-um.pdf
Need more help ? Just post a comment.
Nov 18, 2009 | SanDisk Sansa e250 MP3 Player
Sansa e250
Get the recovery tool from Sandisk Support downloads. Put it in a file you can easily find.
plug in the Sansa, once it turns on, hold the power button until it turns off then switch the hold switch at the top edge of the player to hold (showing orange) and then hold the "Record" button on the side until the player turns on with a black screen, saying it is in recovery mode.
Some people have said they had to hold both "Power" and "Record" to make it work.
Run the recovery tool software and you should be running again.
Jun 26, 2008 | SanDisk Sansa e250 MP3 Player
Sansa e250
alright just take the battery out and put it back in and turn on ur mp3 player.
it takes a little power to take the battery cover off though so dont fell stupid if ur using all ur energy.
Mar 14, 2008 | SanDisk Sansa e250 MP3 Player
LOST SPACE!
same thing happened to me it still doesn't work and mine is supposed to hold 500 it only holds 150
Mar 11, 2008 | SanDisk Sansa e250 MP3 Player
Freezing
I had the excact same thing just turn it on and let the battery run all the way down, then all you have to do is charge it. If this does not work make sure you are running the battery all the way down. Trust me this works.
Good Luck
Feb 17, 2008 | SanDisk Sansa e250 MP3 Player
Sandisk sansa e250 keeps retarting
you should try formating it. when you plug it into your computer... go to my computer right click on your mp3 player name under " devices with removable storage" click format. make sure nothing is checked. and then press start. wait till its done, and it should work. good luck. i can use some to..
May 11, 2007 | SanDisk Sansa e250 MP3 Player
Sansa e250
Just reset ur player using the reset pin available on the player!!
Dec 26, 2006 | SanDisk Sansa e250 MP3 Player
Problem when starting
Hello Devildeiss, Try to format the unit. Follow the steps 6 and 7 of the solution i presented here: http://www.fixya.com/support/t119082-sansa_e270_refresh_database Note that all data on your unit will be erased! But maybe that exterminate with your current problems. Good luck!!! Eduardo.
Oct 03, 2006 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
65 people viewed this question
Top SanDisk Audio Players & Recorders Experts
ThaMp3Doctor
ThaMp3Doctor
Muntejaya Ginting
Muntejaya Ginting
aliasger yq
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
