Question about Canon PowerShot SD300 / IXUS 40 Digital Camera
The camera will not allow me to take pictures. It says=card is locked but I have tried three different memory cards and no luck
Posted by weskaren08 on
CameraR
  • Canon Master
  • 4,738 Answers
Make sure that you are using 2GB or less memory cards for your older camera. 4GB or higher SDHC will not work with an SD300. There are several possible causes for "memory card locked", "memory card error", or "no memory card". Some include trying to use of a 4GB SDHC card with an older camera made before SDHC format came out. Others include problems with the tiny slide switch on the side of the card, or the electrical contact switch internal to the camera. The problem may also arise from simple formatting problems if the card has never been formatted in the camera (note that this will also erase the card). Troubleshooting tips for this problem may be found at this link.
Posted on Dec 25, 2010
My camera says card locked but I have no memory card in the camera. I can not take any pictures
The camera won't take photos without a card unless that model has a menu setting to allow that option (though nothing is stored). Put a different card in the camera and format it. If it doesn't see the card try formatted it first in the computer and then format it in the camera before you try shooting.
2answers
How do i unlock my memory card its not allowing me to take photos.
I am assuming that your camera uses and SD card to store the pictures.
If you remove the memory card from the camera, you should see a little slider on the side of the card that says "lock," it is easy to accidentally lock SD cards.
I have attached a picture to show you what a locked SD card looks like.\:codyrt.jpg
Here is another image showing the card in the unlocked position: codyrt_0.jpg
I’m happy to assist further over the phone at https://www.6ya.com/expert/cody_a1e78820c0d52932
Mar 01, 2011 • Cameras
Memory card not working
If you're sure the slide switch on the side of the card is in the unlocked position, try this. Remove the card and battery...press all the buttons...leave it alone for 20 minutes...insert the card and then the battery...turn it on.
CARD LOCKED
take out the memory card and move the switch located somewhere on the memory card usually on the side to the unlocked position. Then the memory card isn't locked this is so you don't accidentally delete important things
Thanks and enjoy,
Lee
Unable to download pictures from a Vivicam 6200w
I have he same problem with the vivicam 6200W as well. The only solution is to remove the card from the camera and use a SD card reader to read it to the computer. The included driver in the CD ROM will not allow direct access to an installed SD card. Removing the SD memory card will allow you to access the camera memory itself.
The better solution is to cluck the camera away and never ever buy a vivitar again. Get a FUJI or cannon with an underwater water casing.
1helpful
When you try to take pictures it says card locked
on most memory cards, there's a switch that prevents writing to the card. It's on the left edge. Make sure it's "up" (toward the connectors) and not down.
if that doesn't help, try a different memory card. If it still happens, then we know the problem exists with the camera and not the card.
22helpful
4answers
Memory card locked
Sounds like the 'lock' tab on the memory card has been moved to the 'safety' to prevent you from re-writing your card accidentally
Fix it by:
1 remove memory card from camera
2 look for the very little tab/switch on the front of the card
3 slide it to the unlocked position (opposite of now)
4 put it back into camera...should now allow you to take pictures
if the tab/switch is missing do not dispair...
-use a small piece of clear tape to cover this 'tab/switch' opening
-this is the same concept as cassette/vhs/ 5 1/4" floppies...removing the 'tab' to lock it
I recently bought the camera and was able to take 45 pictures without a memory card. I then put a memory card in from my phone and it allowed me to take pictures. However, once I took the card out and...
Be sure that the Lock switch on the memory card in your camera is set to unlock. If it is unlocked then try and see if you can reformat the card with the camera.
1helpful
2answers
Card locked
Make sure the lock isn't on, on the memory card itself.
All SD cards have a lock function on them which keeps any changes from being made to the data that is stored within it.
If you look closely you will see a very small switch on the side of the SD card. Try switching it to the opposite direction and then try to take a picture. If it works then that was your problem all along.
If it doesn't, try switching it back just to make sure.
If you find that neither side works you may want to buy or borrow another memory card to make sure its not a problem with the camera.
Post back if the problem is still their and I will advise further.
Good Luck!
Canon PowerShot SD300 / IXUS 40 Digital Camera Logo
Top Canon Cameras Experts
old marine
old marine
Ekse
Steven Wander
Steven Wander
Are you a Canon Camera Expert? Answer questions, earn points and help others
