Question about Activision Cabela's Dangerous Hunts 2011 with Top Shot Elite for Nintendo Wii
Can't get the top shot elite to connect with my xbox 360 elite halo reach addition
Posted by kevin_benett on
1 Related Answer
Anonymous
SOURCE: cant get my top shot elite gun to sync with my
im having this problem too and i can not figure out why
Posted on Dec 26, 2010
Tip
Top Shot Elite Set Up and Usage Guide by Activision Follow this link to the...
<b><u>Top Shot Elite Set Up and Usage Guide by Activision</u></b><br /> Follow this link to the Guide on <a href="http://www.facebook.com/ActivisionHunts?sk=app_2373072738#!/topic.php?uid=133041143393695&topic=331">Facebook.com/ActivisionHunts</a><br /> Also see the following <b>Expert Videos</b> to have the best gameplay experience with your <b>Top Shot Elite</b>:<br /> <a href="http://www.facebook.com/ActivisionHunts?sk=app_2373072738#!/video/video.php?v=10150089463307966">Top Shot Elite How To Video 1 - Introduction</a><br /> <a href="http://www.facebook.com/ActivisionHunts?sk=app_2373072738#!/video/video.php?v=10150089459077966">Top Shot Elite How To Video 2 - Syncing</a><br /> <a href="http://www.facebook.com/ActivisionHunts?sk=app_2373072738#!/video/video.php?v=10150089455422966">Top Shot Elite How To Video 3 - Calibration</a><br /> <a href="http://www.facebook.com/ActivisionHunts?sk=app_2373072738#!/video/video.php?v=10150089452377966">Top Shot Elite How To Video 4 - Dead Zones</a><br /> <a href="http://www.facebook.com/ActivisionHunts?sk=app_2373072738#!/video/video.php?v=10150089448732966">Top Shot Elite How To Video 5 - Red Lens</a><br /> <a href="http://www.facebook.com/ActivisionHunts?sk=app_2373072738#!/video/video.php?v=10150089445917966">Top Shot Elite How To Video 6 - Troubleshooting</a>
on Feb 17, 2011 | Video Game Consoles & Games
What is the best way to level up in halo reach
firefight match making
harvesting can get you banned
add me gamertag :itslino
:D
Oct 10, 2011 | Microsoft Halo Reach for Xbox 360
Halo reach game unrecognized
it may be your xbox
if you have a white arcade its your xbox
it eventually get worse so save the ones u can on to your hard drive
Oct 08, 2011 | Microsoft Halo Reach for Xbox 360
I need offline xbox 360 mods for halo reach
google or youtube them
they are usually made by people and uploaded so virus scan it first or your computer or xbox may be dead
have fun and remember there are scans on xbox live so check when the scans occur and dont use hacks within the 3 days before or you can get xbox banned :)
Oct 01, 2011 | Microsoft Halo Reach for Xbox 360
Where on the box is the hlo pc key?
The Halo PC key refers to your serial key you have for installing your copy of Halo C.E. for the PC. It isn't located on the Halo Reach box or in any sort of pamphlet included with Reach since it is for an entirely different game.
Jan 24, 2011 | Microsoft Halo Reach for Xbox 360
I just purchased Cabelas dangerous hunts 2001 for my xbox 360 console..... I cannot get the gun to sync with my xbox....Please help!
See the Top Shot Elite Set Up Guide on the Discussions Tab at Facebook.com/ActivisionHunts or contact Activision Assist on Facebook.http://www.facebook.com/topic.php?uid=133041143393695&topic=331
The same is below.
Activision HuntsCablela's Dangerous Hunts 2011: How-to-Guide for the Top Shot Elite
You have two options when playing Cabela's Dangerous Hunts 2011 with your Top Shot Elite. You can either play with the default setting, or you can calibrate the gun to your television set.
Option 1: Default Setting - Sensor Bar Position
The default setting will work fine for most people. However, you will need to ensure that the sensor bar position is set up correctly within the game. If it isn't, you may have issues with aiming and lining up the reticle that appears on the screen.
How to Setup the Sensor Bar Position:
1. From the main menu, select "options"
2. Select "Controls"
3. Make sure that the "Use Calibration" option says "No".
4. Select the Sensor Bar position that matches your setup. Top means that you have the Sensor Bar above your TV, and Down means that you have the sensor bar below your TV.
Option 2: Calibrating your Top Shot Elite
Calibrating the Top Shot Elite is not necessary to play the game, but it can help improve the aiming experience if done correctly. It should be noted, however, that not all homes are ideal for calibration. You should only calibrate if you can stand comfortably 6-8 feet in front of your television.
How to Calibrate:
• From the main menu, select "Options"
• Select "Controls"
• Select "Yes" in the "Use Calibration Option."
• On the calibration screen, you'll see a target in the upper left hand corner of the screen.
• Stand at least 6 feet away, aim through the scope and line up your crosshairs over the target. Pull the trigger to continue.
IMPORTANT: A message will say "Cannot detect gun position" if it cannot read your Top Shot Elite. Usually this means that you're standing too close to the TV. Try backing away from it. If you're still unable to line up the scope with the target, read through the tips section below to ensure proper setup.
• Next, you will see a target on the lower right of the screen. Aim through the scope and pull the trigger to continue.
• Now check the calibration. Look at the screen through the scope. When you move the gun around the screen, the on-screen reticule should stay within view of the scope. As long as the reticle is visible, your calibration should be ok. If, however, you can't see the reticle at all times or you're simply not happy with the results, select the calibrate option to retry.
• Once you're happy with the setting, you'll need to save them. Exit the calibration screen and select "Yes" (you would like to save your settings).
Note: Moving your position within your room may throw off the calibration. If you decide to change positions, we recommend recalibrating for the best results.
Additional Tips and Tricks to Having a Good Experience with Your Top Shot Elite.
1. Room Setup
• Make sure your room is comfortably lit - not too bright. Your TOP SHOT Elite has a built-in infrared camera and will have less trouble seeing the infrared lights from your sensor bar if you turn down some of your lights a bit.
• Make sure you've removed extra lights near or around your television. The TOP SHOT Elite includes a small camera that looks for infrared light. If you've got little lights or even candles around your television, your camera might have a hard time seeing the sensor bar.
• Turn off other gaming consoles. Other gaming consoles might interfere with your TOP SHOT Elite. For example, if you're trying to use your Xbox 360 TOP SHOT and you have your Wii turned on, the sensor bar from your Wii could interfere with the wireless sensor bar for your TOP SHOT Elite.
• Give yourself plenty of room. The TOP SHOT Elite works best if you're standing about 6 to 8 feet from your television. In addition, you want to make sure you don't have any breakable objects near you when you're playing with the TOP SHOT Elite. This includes vases, lamps, other people, and anything else you wouldn't want to accidently hit with your TOP SHOT Elite.
2. Sensor Bar Setup
• Set your sensor bar at a comfortable height. Your TOP SHOT Elite needs to see the sensor bar at all times. Generally speaking, you want to set your sensor bar above or below your television so that it is as close to eye level as possible.
• Make sure your sensor bar is on. Please note that the wireless sensor bars that come with your TOP SHOT Elite don't stay on all the time. To save on battery life, the sensor bars have a built in timer that shuts off automatically. You can set your timer by adjusting the small switch in the back of the sensor to 1, 2, or 3 hours. When your sensor bar is on, you'll see a little red light in the front.
• Why isn't there a Sensor Bar Position option when I calibrate? When you calibrate the Top Shot Elite, the game automatically figures out where your Sensor Bar is, so you don't need to manually set it up.
3. The TOP SHOT Peripheral
• Turn it on and sync it up! Your TOP SHOT Elite peripheral is a wireless controller that needs to be synced to your console. If you need help syncing your TOP SHOT Elite, please refer to the following guide to help you out: Customer Service FAQ
• The forward control stick. Sometimes you need just a little extra help. Located on the front left of your TOP SHOT Elite is a second control stick that you can use to help you quickly turn while playing Dangerous Hunts 2011.
Jan 08, 2011 | Activision Cabela's Dangerous Hunts 2011...
Has microsoft solved the problem with halo reach resetting itself
As far as I know, yes. I bought my copy the day it came out and haven't had a problem with it. It may be defective discs or something of that ilk.
Oct 15, 2010 | Microsoft Halo Reach for Xbox 360
Activision Cabela's Dangerous Hunts 2011 with Top Shot Elite for Nintendo Wii Logo
447 people viewed this question
Top Activision Video Game Consoles & Games Experts
Muntejaya Ginting
Muntejaya Ginting
ray gallant
Are you an Activision Video Game Console and Game Expert? Answer questions, earn points and help others
