Question about Activision Cabela's Dangerous Hunts 2011 with Top Shot Elite for Nintendo Wii
I cannot get the top shot elite to connect with the PS3
Posted by kmojo88 on
Anonymous
    New Friend:
1. Turn off the PS3 system.
2. Make sure the gun and the sensor bar both have batteries in them, and the sensor bar is placed either above or below the TV.
3. Remove the USB connector from the end of the stock.
4. Turn on the sensor bar.
5. Connect the USB connector to the PS3 system.
6. Turn on the PS3 system.
7. Press the PS3 button on the gun.
8. Press the Connect button on the end of the USB connector.
9. Press the PS3 button on the Gun again.
10. Gun must be pointed at the sensor bar to pick it up.
This should fix your problem. Merry Christmas!!!!
Posted on Dec 25, 2010
Top shot elite ps3 controller issues
Check the connector for bent pins or corrosion and then focus on the potentiometer that you adjust for calibration- it is likely dirty. A quick shot of contact cleaner is best- point the spray tube in the gap between the terminals and the metal back (if present) and rotate the control back and forth to cut through the dirt. This should remedy it.
Dec 29, 2011 | Sony Playstation 3 (PS3) Console
Tip
Top Shot Elite Set Up and Usage Guide by Activision Follow this link to the...
<b><u>Top Shot Elite Set Up and Usage Guide by Activision</u></b><br /> Follow this link to the Guide on <a href="http://www.facebook.com/ActivisionHunts?sk=app_2373072738#!/topic.php?uid=133041143393695&topic=331">Facebook.com/ActivisionHunts</a><br /> Also see the following <b>Expert Videos</b> to have the best gameplay experience with your <b>Top Shot Elite</b>:<br /> <a href="http://www.facebook.com/ActivisionHunts?sk=app_2373072738#!/video/video.php?v=10150089463307966">Top Shot Elite How To Video 1 - Introduction</a><br /> <a href="http://www.facebook.com/ActivisionHunts?sk=app_2373072738#!/video/video.php?v=10150089459077966">Top Shot Elite How To Video 2 - Syncing</a><br /> <a href="http://www.facebook.com/ActivisionHunts?sk=app_2373072738#!/video/video.php?v=10150089455422966">Top Shot Elite How To Video 3 - Calibration</a><br /> <a href="http://www.facebook.com/ActivisionHunts?sk=app_2373072738#!/video/video.php?v=10150089452377966">Top Shot Elite How To Video 4 - Dead Zones</a><br /> <a href="http://www.facebook.com/ActivisionHunts?sk=app_2373072738#!/video/video.php?v=10150089448732966">Top Shot Elite How To Video 5 - Red Lens</a><br /> <a href="http://www.facebook.com/ActivisionHunts?sk=app_2373072738#!/video/video.php?v=10150089445917966">Top Shot Elite How To Video 6 - Troubleshooting</a>
on Feb 17, 2011 | Video Game Consoles & Games
Just bought Cabela's Dangerous hunt 2011 and I'm having trouble syncing gun with console, any advice? Thanks
See the Top Shot Elite Set Up Guide on the Discussions Tab at Facebook.com/ActivisionHunts or contact Activision Assist on Facebook. http://www.facebook.com/topic.php?uid=133041143393695&topic=331
The same is below.
Activision HuntsCablela's Dangerous Hunts 2011: How-to-Guide for the Top Shot Elite
You have two options when playing Cabela's Dangerous Hunts 2011 with your Top Shot Elite. You can either play with the default setting, or you can calibrate the gun to your television set.
Option 1: Default Setting - Sensor Bar Position
The default setting will work fine for most people. However, you will need to ensure that the sensor bar position is set up correctly within the game. If it isn't, you may have issues with aiming and lining up the reticle that appears on the screen.
How to Setup the Sensor Bar Position:
1. From the main menu, select "options"
2. Select "Controls"
3. Make sure that the "Use Calibration" option says "No".
4. Select the Sensor Bar position that matches your setup. Top means that you have the Sensor Bar above your TV, and Down means that you have the sensor bar below your TV.
Option 2: Calibrating your Top Shot Elite
Calibrating the Top Shot Elite is not necessary to play the game, but it can help improve the aiming experience if done correctly. It should be noted, however, that not all homes are ideal for calibration. You should only calibrate if you can stand comfortably 6-8 feet in front of your television.
How to Calibrate:
• From the main menu, select "Options"
• Select "Controls"
• Select "Yes" in the "Use Calibration Option."
• On the calibration screen, you'll see a target in the upper left hand corner of the screen.
• Stand at least 6 feet away, aim through the scope and line up your crosshairs over the target. Pull the trigger to continue.
IMPORTANT: A message will say "Cannot detect gun position" if it cannot read your Top Shot Elite. Usually this means that you're standing too close to the TV. Try backing away from it. If you're still unable to line up the scope with the target, read through the tips section below to ensure proper setup.
• Next, you will see a target on the lower right of the screen. Aim through the scope and pull the trigger to continue.
• Now check the calibration. Look at the screen through the scope. When you move the gun around the screen, the on-screen reticule should stay within view of the scope. As long as the reticle is visible, your calibration should be ok. If, however, you can't see the reticle at all times or you're simply not happy with the results, select the calibrate option to retry.
• Once you're happy with the setting, you'll need to save them. Exit the calibration screen and select "Yes" (you would like to save your settings).
Note: Moving your position within your room may throw off the calibration. If you decide to change positions, we recommend recalibrating for the best results.
Additional Tips and Tricks to Having a Good Experience with Your Top Shot Elite.
1. Room Setup
• Make sure your room is comfortably lit - not too bright. Your TOP SHOT Elite has a built-in infrared camera and will have less trouble seeing the infrared lights from your sensor bar if you turn down some of your lights a bit.
• Make sure you've removed extra lights near or around your television. The TOP SHOT Elite includes a small camera that looks for infrared light. If you've got little lights or even candles around your television, your camera might have a hard time seeing the sensor bar.
• Turn off other gaming consoles. Other gaming consoles might interfere with your TOP SHOT Elite. For example, if you're trying to use your Xbox 360 TOP SHOT and you have your Wii turned on, the sensor bar from your Wii could interfere with the wireless sensor bar for your TOP SHOT Elite.
• Give yourself plenty of room. The TOP SHOT Elite works best if you're standing about 6 to 8 feet from your television. In addition, you want to make sure you don't have any breakable objects near you when you're playing with the TOP SHOT Elite. This includes vases, lamps, other people, and anything else you wouldn't want to accidently hit with your TOP SHOT Elite.
2. Sensor Bar Setup
• Set your sensor bar at a comfortable height. Your TOP SHOT Elite needs to see the sensor bar at all times. Generally speaking, you want to set your sensor bar above or below your television so that it is as close to eye level as possible.
• Make sure your sensor bar is on. Please note that the wireless sensor bars that come with your TOP SHOT Elite don't stay on all the time. To save on battery life, the sensor bars have a built in timer that shuts off automatically. You can set your timer by adjusting the small switch in the back of the sensor to 1, 2, or 3 hours. When your sensor bar is on, you'll see a little red light in the front.
• Why isn't there a Sensor Bar Position option when I calibrate? When you calibrate the Top Shot Elite, the game automatically figures out where your Sensor Bar is, so you don't need to manually set it up.
3. The TOP SHOT Peripheral
• Turn it on and sync it up! Your TOP SHOT Elite peripheral is a wireless controller that needs to be synced to your console. If you need help syncing your TOP SHOT Elite, please refer to the following guide to help you out: Customer Service FAQ
• The forward control stick. Sometimes you need just a little extra help. Located on the front left of your TOP SHOT Elite is a second control stick that you can use to help you quickly turn while playing Dangerous Hunts 2011.
Jan 08, 2011 | Activision Cabela's Dangerous Hunts 2011...
Can not get the360 xbox console to recognize that we have the gun, we turn on the sensor bar that came with game and we also have the kinetic sensor for xbox
The same is below.
How to Calibrate:
• Select "Controls"
1. Room Setup
2. Sensor Bar Setup
Jan 04, 2011 | Activision Cabela's Dangerous Hunts 2011...
How do I get started using the gun?
The same is below.
How to Calibrate:
• Select "Controls"
1. Room Setup
2. Sensor Bar Setup
Jan 03, 2011 | Activision Cabela's Dangerous Hunts 2011...
Problem with the Activision Cabela's Dangerous Hunts 2011 with gun for Xbox 360. When aiming for calibration it wont turn red unless you point gun directly at sensor bar
The same is below.
How to Calibrate:
• Select "Controls"
1. Room Setup
2. Sensor Bar Setup
Dec 31, 2010 | Activision Cabela's Dangerous Hunts 2011...
How do I sync my gun with my PS3 for Cabelas 2011
Dec 25, 2010 | Activision Cabela's Dangerous Hunts 2011
Activision Cabela's Dangerous Hunts 2011 with Top Shot Elite for Nintendo Wii Logo
1,823 people viewed this question
Top Activision Video Game Consoles & Games Experts
Muntejaya Ginting
Muntejaya Ginting
ray gallant
Are you an Activision Video Game Console and Game Expert? Answer questions, earn points and help others
