Question about Samsung RS265TD
We have a four month old Samsung RS265TD fridge/freezer side by side. The temperature display for both started showing "OF" last night. We can reset but, it immediately returns to "OF" for both. Food in freezer is still frozen but, water placed in freezer last night has not yet frozen. Is there anything we can do to correct the tempuratures today?
  • Chris Huff
    Chris Huff Sep 08, 2017
    That should read demo mode.
Chris Huff
    Top Expert:
  • Samsung Master
  • 6,289 Answers
It's in Demi mode.
Posted on Sep 08, 2017
5 Related Answers
Anonymous
SOURCE: samsung rs2555sl The fridge has stopped cooling - power is getting to it and the freezer part is still working.
Mine exact same model has the same problem. It is caused by a small leak that can't be repaired by the Best buy repair man. The refrigerant slowly releases over time and the compressor works harder and harder and then finally either the refrigerant is gone or the compressor burns up. Best buy knew this when they sold it to me as a "Floor Model", the "BEST BUY" repair man told me that they had repaired it already once before I bought it. I was ripped off by Best Buy, they told me it was just a floor model that was only out for a few weeks. It was a return because it failed and they just pumpped it up with refrigerant and sold it again to an unsuspecting customer.
Posted on Feb 07, 2007
douglas smith
  • 1462 Answers
SOURCE: SAMSUNG SIDE BY SIDE FRIDGE FREEZER
these appliances are a pain in the butt. fault with water dispensor is oprob that the water bottle at bottom of fridge is frozen. rise in temp is prob that defrost not taking place. not a diy unless you are experienced
Posted on Mar 20, 2007
Anonymous
SOURCE: Samsung RCS21DCNS Side by Side
probly the evaporator coil in fridge all frozen up you need to pull all the back out inside the fridge section and defrost with air drier
Posted on Sep 21, 2007
Charles Caldwell
  • 66 Answers
SOURCE: the refrigerator section is freezing. the temp adjust is at 1
This could be the actuator is not closing the door that controls how much cold air from the freezer is ciculated into the fresh food section. It could be something broken or there could be ice biuldup on the door itself, not allowing the door to open or close.
Posted on Nov 12, 2008
Anonymous
SOURCE: SAMSUNG RS20CCMS AMERICAN STYLE FRIDGE FREEZER
in the freezer section there is a 6 screws. unscrew them and remove the back panel. there will be 2 wires attached to the panels, remember where they go. you will see a metal evaporator which will be filled with ice. this is the problem. use a hairdryer to melt the ice. this is essential as you mustn't puncture the wall of the fridge with any sharp item. before replacing the panel ensure that everything is dry or ice will reform, and also ensure that the fan blades are turning properly or cold air will not be blown into the fridge.
Posted on Dec 10, 2008
My refrigerator shows a code "OF" or "0F" where the temperature settings usually show, we tried to put the temperature settings back but couldn't. We unplugged the refrigerator to reset it but it sti
Cooling Off mode (also called Shop mode), is designed for use by retailers when they are displaying refrigerators on the shop
floor. In Cooling Off mode, the refrigerator's fan motor and lights work normally, but the compressors do not run, and
the refrigerator and freezer do not get cold.
To start Cooling Off mode, Touch and hold the Energy Saver button and the Power Freeze button for 3 seconds during normal
operation.
The refrigerator chime sounds and the temperature display flashes OF OF.
To cancel Cooling Off mode, Touch and hold the Energy Saver and the Power Freeze buttons again for 3 seconds.
Source: http://downloadcenter.samsung.com/content/EM/201104/20110414114919054/110323-QS_Guide-POLARIS-EN.pdf
Dec 30, 2013 | Samsung Real Stainless Steel 30 Cu Ft Side...
Help with Light for Fridge RS265TD RS
Most refrigerators have a switch somewhere. look for a little white triangle either at the top or bottom. there may be a push button style somewhere along the upper hinge cover.
Nov 05, 2013 | Samsung RS265TD 26 cu. ft. Side by Side...
What does OF on the display mean?
If you get the message OF on your Samsung refrigerator here is how to correct it. What OF means is your freezer and refrigerator has or is going to stop and warm up. To correct it push the Light+Freezer buttons for 3 seconds. It will reset to the last temp settings and everything should go back to normal.
Feb 06, 2013 | Samsung RS265TDRS Side by Side...
GE PFSS6PKW display shows "88" on freezer side and
my fridge had the same prob thank you very much this really works i pressed the energy and alarm for 10 seconds and works PERFECT
Nov 15, 2010 | GE Refrigerators
We lost power last night and it came back on our digital display onthe fridge just has one dash and will not allow me to set temperatures
When the freezer is below -12 degrees, you will not be able to set the temperature.
Should be ok after a period of up to 3 hours.
Hope this helps
Sep 29, 2009 | Samsung Refrigerators
Samsung fridge freezer not cold enough
Hello whiten61,
Welcome,
You said, You noticed there was condensation in my fridge and a strange smell coming from it, also my freezer was cold but didn't seem to be cold enough, I have a digital display and it was still showing -22 for freezer and 3 for fridge. I turned the power off on the wall and when i turned it back on which was straight away it shown -3 for freezer and 16 for fridge... I then noticed the ice cream in freezer very watery, however ice in freezer still frozen? i pressed the quick freeze button which eventually the temperature came back up but i keep getting the exact same problem... Can you help. thank you.
Samsung side by side refrigerator SR-S2025CVW
How old is the fridge?
You did all the right things!!
But this sounds like a bad thermostat.
or a bad control switch.
Unfortunately it sounds like you may need service to do an hands on diagnoses and replacement of one of these parts I listed here!
Let me know how you do! Or if you need something else.
We do have very good sponsors here on this site that do repair work, should you take this course!
Huuum
Please remember to leave a rating.
Oct 14, 2008 | Samsung RS2630SH Side by Side Refrigerator
Fridge and Freezer do not keep foods cool
Samsung rs2630ww i have had endless problems i have had it replaced 4 times. red hot center and side panels i have had 2 condensers burn. the problem is that it is simply badly designed!
there is not enough air flow . so if it has any restriction it kills the unit. a Samsung tech told me off the record these units are all problematic! of course he love it at 200 an hour.
Aug 01, 2007 | Samsung RS2630WW Side by Side Refrigerator
Samsung RS265TD Logo
196 people viewed this question
Top Samsung Refrigerators Experts
Michael Thomas
Michael Thomas
Marvin
Marvin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
