Question about Dell Inspiron 1501 Notebook
My Dell Inspiron 1501 laptop screen suddenly went black when I was using the laptop.It went completely dead. I have tried connection the adapter to a different power outlet, disconnected and reconnected the AC adapter,Removed and put in the battery again. But nothing works. When I press the power button no indicator light comes on. Infact the green light on the power adapter goes off. What is wrong ? How Can I solve this problem.
  • Anonymous Dec 26, 2010
    I dont think you understood the problem. The computer does not switch on at a;; on pressing the power button , neither with battery nor with AC adapter plugin. So how do I perform the steps you have suggested?
  • Anonymous Jan 15, 2011
    Thanks for all the tips. Nothing worked. I had my laptop examined and repaired by a trained technician. The problem was in the mother board. It has been repaired and the machine is switching on now and working.
Kiran Aradhya
    Guru:
  • 443 Answers
Follow the below steps it would fix your issue.
Method 1: First you need to try safe mode and check if you are able to boot to the desktop.
Follow this below provided link to start your computer in safe mode.
Advanced startup options including safe mode
http://windows.microsoft.com/en-US/windows7/Advanced-startup-options-including-safe-mode
Method 2:
If you are able to boot into safe mode then in order to troubleshoot this issue further, you may unplug all the external devices except keyboard and mouse and check if you are able to boot to the desktop.
Method 3: If the above provided steps don't resolve the issue then, I would recommend you perform startup repair.
Follow these steps:
To perform a Startup Repair follow the steps below:
a. Please insert the Windows 7 DVD and reboot the computer.
b. When we are prompted to press a key to boot from the DVD, please press Enter or the space bar.
c. Choose your language settings, and then click Next.
d. Click Repair your computer.
e. Select the operating system you want to repair, and then click Next.
f. On the System Recovery Options menu, click Startup Repair. Startup Repair might prompt you to make choices as it tries to fix the problem, and if necessary, it might restart your computer as it makes repairs.
Access the link below for more information about startup repair:Startup Repair: frequently asked questions
http://windows.microsoft.com/en-US/windows7/Startup-Repair-frequently-asked-questions
Posted on Dec 25, 2010
  • 1 more comment
  • Kiran Aradhya
    Kiran Aradhya Dec 26, 2010
    my apologize sir, i am so sorry for that and i am sure this wont happen again.
    When did you buy your laptop? Is it under warranty? Contact your Hardware Vendor. This would help you. I suspect its a problem with the hardware.
  • JohnLC Jan 10, 2011
    From a search on google and looking at friend's and relatives around me, it seems like the Inspiron 1501 was programmed to fail in December 2010 on the power side. You can check with your customer protection agency right away since Dell did not reply much on that issue. At best you will end up with a laptop which only work with AC in without battery.
  • Kiran Aradhya
    Kiran Aradhya Jan 10, 2011
    Fine i would look into it,have you tried to remove he battery and press power button for some 30 seconds. Have You tried using a diffrent charger?
    Post back for more solutions we will be happy to help you.
    Hope this helps.
    Cheers!!!!
I had been using my computer when all of the sudden screen went black and I could hear the windows shutting down. I thought maybe my battery was dead and I was not paying attention, so charged it. But when...
Do a hard reset by turning off the computer and removing the battery and unplug the AC adapter. Without any power source, press and hold the power button and put everything back after. Power on the computer again, if it does not work, try to connect your laptop to an external monitor. If it shows some display it means that the LCD monitor of your laptop has gone faulty.
I am using a Dell Laptop and it is inspiron 1501. But its battery is not charging. I get 2 error message the adapter can not recognise... The battery can not recogise.. Something like that. The laptop gets...
try to remove the battery from the computer, after unplugging it, plug in the AC adapter without the battery and check if it will turn on. if it doesnt then 2 possible reason
1. the AC adapter is busted, you can try a known good Dell AC adapter. if its still now working with a know good AC adapter then
2. its the motherboard that needs to be replaced.
Hope this help
Screen went black and it won't reboot
remove the battery and unplug the power adapter. press power button for 30 sec. then connect power adapter. press power button.
Dell inspiron 1501 display almost blank
Try changing the memory stick, if still doesnt work, it means the invertor of the screen is gone.
3answers
Desktop goes black/blank after opening
Can you go to safemode and check if you are able to see the icons.
Did you run a virus scan lately. If not you can try that.
Let me know the results and i can guide you further.
2answers
My daughter was on my dell inspiron 1501 laptop, all fine, i asked to use it for 5 minutes, i unplugged it from the adapter and used it in another room, i returned it still on my daughter plugged it back...
The inspiron has known issues with overheating and heatsink fan issues.. Contact dell tech support if under warranty or just buy a new motherboard cause yours is probably dead now.
For the first problem, try reseating the memory and the battery, see if any thing happens if you leave the battery out and plugged in using the AC adapter only.
Good Luck.
For the second problem, try removing the battery for about 10 minutes then after installing the battery power up and see if the display if full again, if so grate, if not, you will probably need to have a tech fix it, as either the display is bad or maybe the connector inside the laptop became loose and should only be repaired by a qualified technician.
Good Luck.
Dell inspiron 1501 wonnect wireless network?
inspiron 1501..the DVD no play more.write
DELL INSPIRON 1000
Try the following:
1. Try to boot the notebook with both battery and adaptor attached.
2. Try to boot with ONLY the battery.
3. Try to boot with ONLY the adapter.
If you can't boot with only the adapter, the adapter has died. If you can't boot with only the battery, the battery is dead.
But as stated above, make sure your battery is sufficiently charged.
In case of a dead battery or adapter, check whether the device is still under warranty. Contact HP if so.
Let me know what you found out.
Greetings,
DarkNeogen
Dell Inspiron 1501 Notebook Logo
Ekse
Mandeep  Singh
Mandeep Singh
Mehandi Husain ...
