Microsoft Xbox 360 Console Logo
Posted on Dec 25, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Xbox will not power up - Microsoft Xbox 360 Console
Muntejaya Ginting
Level 3:
  • Master 10,422 Answers
  • Posted on Dec 25, 2010
Muntejaya Ginting
Master
Level 3:
Answers
10422
Questions
Helped
2467781
Points
19564
Hi, A totally died xbox is telling you there is no power feeds to the device Please check your power supply line. Use VOLTMETER to get the voltage output of your power supply. If there is , please trace the power goes to circuit board of Xbox. There should something problem and need to fix there.
Regards, Jay
2answers
When i turn on my xbox i'm getting 3 flashing red lights what does this mean
it means your xbox is overheating, you can send it back as they extended the warranty on it for this common fault unless you have modified it, in which case look up ring of death on youtube.
Power supply light stays orange and wont turn on the XBOX PRO. HELP!
I hope this helps The power supply light is orange for one of the following reasons:
  • The console is turned off.
  • The power supply is not plugged into the console or the connection is not tight.
  • The power supply is not functioning properly.
Note An orange light usually indicates that the power supply is connected to electricity and ready to power the console. When you turn on the console, the power supply light should change from orange to green. If your console does not turn on, please see the following Knowledge Base articles: 907588 (http://support.microsoft.com/kb/907588/ ) Your original xbox 360 console will not turn on
2122656 (http://support.microsoft.com/kb/2122656/ ) Your xbox 360 S console will not turn onIf the console will not power on and you have tried the troubleshooting steps in the above article, your power supply will need to be replaced.
Contact xbox Support to obtain a replacement power supply. For information about how to contact xbox Support, visit the following website: www.xbox.com/support/contact (http://www.xbox.com/support/contact)
2answers
How to setup xbox live
Hello there
No problem, in just a few steps you too will be online and ready to go.
Ethernet Cable
With your Xbox 360 turned off unplug the ethernet cable from the back of your Xbox.
Xbox 360 Power Cord
Next unplug the Xbox 360 power cord from the back of the Xbox 360.
Unplug ethernet cable and power cord from the modem. Wait for about 1 minute and then plug ethernet cable back into the modem.
Now you need to plug other end of the ethernet cable into the back of the Xbox 360.
Plug the modem power cord back into your modem , wait for lights to light up on your modem (this can take up to a minute).
The last step is to plug the Xbox power cord into the back of the Xbox, turn it on and you are ready to go.
10helpful
2answers
Power box light is blinking orange and sometime a steady red and console want come on.
Green Indicator Light:
The default indicator light is green. When the Xbox 360 power supply light is green it means that there are no problems with your power supply. However, if you are having problems and the power supply light is green, this means that the console is faulty and you need to contact Xbox 360 support.
Orange or Yellow Indicator Light
When the Xbox 360 power supply light is orange or yellow this means there is no problem with your console but the power supply can't supply it with power.
To remedy this problem, first try unplugging the Xbox 360 power supply from the console and unplug the power cord from the wall outlet. You'll also want to uplug the Xbox 360 power supply from the power cord.
Wait for about five minutes and then reconnect everything. You might also want to try plugging it into another wall outlet without an extension cord.
If you are still getting an orange or yellow indicator light, then something is at fault with the Xbox 360 power supply. If this is the case, contact the Xbox 360 customer support to get a new one.
Red Indicator Light:
If the xbox 360 power supply light is red, then there is something wrong with the power supply connection. If this is the case, try the same solution as listed above of unplugging the power supply from the console, unplugging the power cord from the wall outlet and unplugging the power supply from the power cord. Wait for about five minutes and then reconnect everything. You might also want to try plugging it into another wall outlet without an extension cord.
If the indicator lights are still red, then there is a fault with the power supply. If this is the case, contact customer support about getting a new one.
No Indicator Light:
If the XBox 360 power supply light is not illuminating at all, this usually means that the Xbox power supply is not connected to the wall outlet correctly. On the other hand, it might also be a fault with the power supply or the power cord.
Either way, try the same solution as listed above for the red indicator lights. If you still don't see any lights illuminated after unplugging and then reconnecting everything, you'll need to contact customer support about getting a new power supply.
Green and Orange Indicator Light:
If the indicator light is flashing green and orange, this may mean that the console does not detect the AV Pack.
Disconnect and then reconnect the Xbox AV Pack. Make sure the connections are firmly connected. Turn your Xbox back on.
If the indicator light is still flashing green and orange, try another AV pack if one is available.
If the indicator light is still flashing green and orange, you'll need to contact Miscrosoft Customer support.
Flashing Orange Indicator Light:
If your Xbox console's indicator light flashes orange, this means the internal components have overheated and the Xbox has automatically shut down to prevent damage.
Turn off the console and let it cool for at least 10 minutes.
To prevent the Xbox from overheating in the future, make sure that it's not placed in a closed cabinet or on carpet. It's best to get the Xbox elevated off the ground where the PSU can have maximum heat release.
You'll also want to make sure the Xbox is not located near a heat source like the back side of a television, computer, monitor, or other electrical device.
2answers
I dont know how to set up my xbox live with an eathernet cable can you help?
Hi there
Turn off the Xbox 360 by pressing the power button on the front of the console. Afterward, shut off your modem by unplugging its power cord.
  • 2 Insert one end of the Ethernet cable into the Ethernet port located at the back of your Xbox 360 console. After that, insert the other end of the cable into your modem.
  • 3 Replug the power cord into your modem to turn it back on. Once it is active, press the power button on your Xbox 360 to turn it on.
  • 4 Navigate to "My Xbox" then "System Settings." Afterwards, select "Network Settings" then "Test Xbox LIVE Connection." You will be notified on-screen if the connection is successful.
  • Read more: How to Set Up Xbox LIVE with an Ethernet Cable | eHow.com http://www.ehow.com/how_6714462_set-xbox-live-ethernet-cable.html#ixzz0xBK8Zctz
    GOODLUCK!!
    4helpful
    3answers
    Xbox 360 won't turn on
    I had this problem. Make sure the pins in the USB ports (2 on the front and 1 on the back of the console) aren't bent and there's nothing obstructing them. I unbent some of the metal inside these ports, and voila! I have a working xbox.
    16helpful
    2answers
    Power brick colour
    Alright, lets fix this!
     Xbox 360 power supply light is orange or yellow.
    Usually when the Xbox 360 power supply light is orange it's on standby so there is no problem with your Xbox 360 console but the power supply can't supply it with power !
    First you have to try unplugging the Xbox 360 power supply from the console & unplugging the power cord from the wall outlet also unplug the Xbox 360 power supply from the power cord, wait for a minute then reconnect it all back , also try it on another wall outlet without any extension cords at all.
    If it's still doing the same it will be definitely a fault with the Xbox 360 power supply.
    So, in this case please contact Xbox 360 customer support to fulfill the Xbox 360 power supply.
    Xbox 360 power supply light is red.
    There is something wrong with the Xbox 360 power supply connection so try unplugging the Xbox 360 power supply from the console & unplugging the power cord from the wall outlet also unplug the Xbox 360 power supply from the power cord, wait for minute then reconnect it all back , also try it on another wall outlet without any extension cord at all.
    If it's still red that would be for sure a fault with the Xbox 360 power supply .
    So, then contact Xbox 360 customer support to fulfill your Xbox 360 power supply .
    You can also find replacement power cords many places online. See if you can get your hands on another cord and try that to see if its the current power cord.
    Hope this helps you out! Please don't forget to rate :)
    My original xbox has no power at all.could it be power supply?
    It sounds to me like the PSB. (power supply board)  you can get them fairly cheap, but you have to know what version your xbox is.  If you are unsure, google "determining xbox version".  Then go to ebay or http://www.llamma.com/xbox/
    Here is one for about $15
    http://cgi.ebay.com/Xbox-System-Power-Supply-Board-PSU-V1-0-1-5-V1-6-New_W0QQitemZ230329485609QQcmdZViewItemQQptZVideo_Games_Accessories?hash=item230329485609&_trksid=p3286.c0.m14&_trkparms=72:1234|66:2|65:12|39:1|240:1318|301:0|293:1|294:50
    2helpful
    Xbox360
    Top Microsoft Video Game Consoles & Games Experts
    Grand Canyon Tech
    Grand Canyon Tech
    ELECTRICKSUSA
    ELECTRICKSUSA
    Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
