Fujitsu 36CS Air Conditioner Logo
Posted on Dec 25, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Eee code displayed - Fujitsu 36CS Air Conditioner
R Subramaniyam Iyer
Level 3:
  • Master 2,133 Answers
  • Posted on Dec 25, 2010
R Subramaniyam Iyer
Master
Level 3:
Answers
2133
Questions
Helped
952688
Points
6173
To work out what the error code is press the orange start/stop button on the remote controller so unit operation is stopped.
Then press and hold "energy save" and "zone control" button simultaneously for at least five seconds, the error code will be along the lines of En:nn where the "En:" is the error code and the ":nn" indicates the indopor unit address if there are multiple indoor units connected to the one controller. If the upper vertical bar on the capital E is missing so it looks maybe like a 2 or something don't worry for some reasons they just do that
Some common error codes are:
E0 Communication error between indoor unit and wired remote control, check if there is 12VDC between terminal 1 + 3 at remote control and 8-9VDC pulsating between terminal 2 + 3. If DC volts out of Indoor pcb is below about 11.6VDC it will cause this error, the problem is normally dry capacitors in the 12 VDC power supply section. This model has two power supply sections on indoor pcb.
E1 Communication error between indoor unit and outdoor unit,
EF Discharge temperature abnormal
airconditioning
Level 1:
New Friend:
  • Contributor 40 Answers
  • Posted on Mar 10, 2014
airconditioning
Contributor
Level 1:
New Friend:
Answers
40
Questions
0
Helped
95127
Points
56
2helpful
2answers
I have a fujitsu invertor AOT54LJBYL and the key pad comes up with EEE
When EE:EE is displayed on remote control , press "Energy Save" &"Zone Control" buttons simultaneously for longer than 3 secs. The error code will then be displayed on the LCD.After getting error code, please write here to get solution. Thanks.
On my ASUS eee notebook the display flipped 90 degrees. How can I get it back to normal?
To change the display from portrait to landscape
Press Ctrl-Alt plus a left or right arrow key.
1helpful
I called volvo got the code punched in and radio shows EEE after code is put
if you punch in 3 consecutively with a wrong code, the EEE message will be displayed. in order to erase this, you need to place your ignition key at # 1 and switch on the radio and leave it at least between 4 to 6 hours. the code display will come back and re-enter the correct code.
Asus Eee PC 900A will not start
Dear Friend,
1. First Check with connecting External Monitor, if you get display on external monitor that means Display Screen has gone bad
2. If there is no Display on external monitor then there is problem with Motherboard which needs to checked at Service centre.
I have sam problem, all lights are on, they work, but also i can't see nothing in the display, the display is like off. Please help me!
This could be indicating an error code.
If you get in touch with the manufacturer, they will identify what the error is.
Asus eee pc. upon startup it displays normally
ur display is not sync to the signal being rcd from the PC....visit a hardware engineer....
Volvo 940 stereo EEE ??
It is showing EEE because of wrong codes being entered previously,.
To reset it, leave it SWITCHED ON...UNDISTURBED for as long as it takes.
This could be many hours as the waiting time doubles after each wrong code
EEE display code error on CT3600 Honeywell
I am a honeywell dealer and this stat is obsolete and no longer supported. I am not able to pull any info on this. It might be time for a new one.
58helpful
4answers
Asus eee pc900 built-in webcam no display
plz give me drivers of asus Eee pc 900 webcam drivers
Asus eee pc 1000h
you can check whether display is coming or not by connecting it to a monitor through vga port, if its coming then the problem is in display panel
Top Fujitsu Heating & Cooling Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
ADMIN Andrew
ADMIN Andrew
Are you a Fujitsu Heating and Cooling Expert? Answer questions, earn points and help others
