Vizio XVT472SV 47 in. HD-Ready LCD TV Logo
Posted on Dec 25, 2010
Snowy line on top and bottom of screen. - Vizio XVT472SV 47 in. HD-Ready LCD TV
Anonymous
Level 1:
New Friend:
  • Contributor 21 Answers
  • Posted on Dec 25, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
21
Questions
0
Helped
3452
Points
60
Dear Friend,
  1. If the picture you can see is clear and the are bars of snow at top and bottom of the picture, there is a problem of LCD panel of your TV. There is some thing called TCON board which control LCD Panel, may be damaged.
  2. If software of the LCD tv is corrupt, you can update it by contacting service people.
LG MODEL#RM-26LZ30 PICTURE seems scrambled and vertical lines trough the middle of screen
DEPENDS ON WHICH BOARD THAT NEEDS REPLACING. Look on Shopjimmy.com they list boards and parts. If you know how to solder I would first resolder boards and check for Bad Capaciotrs they will be puffed up on Top.
Hitachi 57S500 fuzzy/snowy line at bottom of screen, mostly on left side
experts are free to choose to or not to answer any question..
the issue is very vague so limits some answer, is the line colored, present when a DVD etc connected via rear inputs, or 3 d like in some way?
What would cause a GE 60GW948 have a very snowy, and now No picture screen
when you say gone out---no light on screen or brightness or what? The snowy picture can be got around in most cases.
Lg plasma DT50py10. When turning on bottom half of screen is snowy and has lots of white lines for approx 20 min then it goes away. Top half of screen is normal
sounds like your bottom buffer board is on its way out .
Will also need to check the y sus board as this some times causes the buffers boards to fail.
I have an LG 42'' PDP42V60001 plasma TV it has a white line running from top to bottom covering around a 1/4 of the screen, it moves accross the screen and the rest of the screen is black. Intermittently...
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
I have 2 ps3 consoles one new slim model other is older model both attached to 1080p 120hz tv's one sony one sharp aquos both using top of line $300 monster cable hdmi cables. The ps3 menu screen on both...
did you try going through the settings to configure yur tv with the game console so they could work together properly.also make sure your hdmi cables are good ones.and also try to reset the contrast,brightness etc of the tv.
Horizontal lines on screen
well if they run all the way up and are on every input through then menu the panel is NG, some panels are around $500 now.
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
LCD screen Olympus Stylus 1010 snowy and fuzzy with lines
This is a issue with just the LCD it needs to be replaced.
No picture
need chassis # ctc something look for it on the back cover
Top Vizio Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
