Rheem RTG-74PVN-2 Natural Gas Pronto Whole House, Natural Gas, Tankless Wat Logo
Posted on Dec 25, 2010
Water heater does not come on all of the time.it will give you an error code ao-21 or c2-11
A.O. Smith Water Heater. What does error code of 991 indicate?
Here you are Dorothy
AO Smith code 991 Solution for error code 991
Check the gas type of the water heater. Inspect the environment around the water heater. ... Check if there is grease and/or dirt in the burner (Part #101) and the fan motor (Part #103), especially if the water heater has been installed in a contaminated area.
Error code '991' for type ATI-110C-N by AO Smith. Cause and ...
More help here, but you probably need a service call, especially if it is a gas water heater.
https://www.google.com/search?q=error+code+of+991
Whirlpool ES50R12-55 water heater, error code 7 on display. what does this mean? how can I unlock the buttons on the display to fix error?
Error codes for both types of honeywell gas control valves appear on following link...
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#honeywell
Whirlpool no longer sells water heaters ... but in the past, they sold the AO Smith brand flue damper and atmospheric heaters ... both use different Honeywell gas controls.
AO SMITH VOLTEX ERROR CODE ELEMENT ON HEAT PUMP FAULT ON SCREEN
Copy following link
http://waterheatertimer.org/pdf/AO-Smith-heat-pump-service-manual-321547.pdf
Contact AO Smith for qualified technician in area.
Don't buy expensive water heaters.
Gene
h
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
I need to remove the stored error codes from memory.Replaced board but forgot to drain tank of hot water before calibrating system.E36 code is now stored in H11-H20 because of several attempts to restart.
Call manufacturer.
State water heaters are made by AO Smith, and AO website posts service manuals with each product on literature tab.
Gene
h
2answers
AO Smith Heater/Vacation Mode
Most recent power shot has intellivent gas control valve:
Copy following link to troubleshoot by type of gas control valve:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
Generally you can wake up the control by holding down both temperature adjustment buttons for 1 second then release.
Otherwise, add a comment and give more information, if this is new heater or old heater that stopped working, and what error code if any you are experiencing.
http://www.thetankatwaterheaterrescue.com/forums/forum3/
Post question with more detail on pro water heater formula.
More information is needed... and fixya truncates free questions so not sure I am seeing whole problem
Comes on for appx 20sec then gives code ao21
Before calling service technician, open following link for Rheem troubleshooting resources including error codes, Rheem chat and phone number, possible instruction manual, maintenance manual.
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Error codes are considered start point for troubleshooting.
Error code 21 is "malfunction of air intake filter switch"
Make sure air filter door is properly seated.
Make sure front panel is properly installed.
http://waterheatertimer.org/pdf/Tankless-maintenance.pdf
1helpful
Error code 21 A1
This means the air intake cover problem.
21
Malfunction of Air Intake Filter Switch Ensure air filter door is properly seated. Ensure front panel is properly installed.
Error codes here: http://www.palomastore.com/paloma_error_codes.html
I am getting error code AO and the temperature
its most likely diplaying a code... is it code 21? that usually will follow ao. first make sure the door is securely on, if not make sure it contacts the switch
Top Rheem Water Heaters Experts
Mike Cairns
Mike Cairns
Sean Wright
Sean Wright
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
