Question about Whirlpool Duet GHW9150P Front Load Washer
Light reads "control locked" and washer won't work
INDIRA KUMAR
  • 5,081 Answers
Please Turn On your washer and hold the END OF CYCLE button for about 10 seconds and that would surely unlock your washer.
Posted on Dec 25, 2010
Testimonial: "Wow. Typed in a question about my front load washer and less than 30 seconds later I had a response that corrected the problem. WOW."
  • INDIRA KUMAR
    INDIRA KUMAR Dec 25, 2010
    Thank you for using fixya
Control locked light is on, washer won't work
If this is a Maytag Epic, Whirlpool Duet, or Kenmore Elite, the following link explains how to lock/unlock this feature:
http://www.fixya.com/support/r3608801-control_panel_lock
Apr 05, 2013 | Washing Machines
It won't work with the "Control Locked" light on
What is the model number of your unit?
Nov 23, 2012 | Washing Machines
I has a Crosley Washing Machine Top Loader. Fill light comes on lid locks then NOthing!
seethis causes and fix it. God bless you
User Control and Display Board If the washer won't start, the user control and display board may be defective. Check for power to the washer first.
Timer If the washer won't start the timer might be defective. This part is often misdiagnosed, check other components before replacing this time
Line Fuse If the washer won't start the line fuse might have blown.
Thermal Fuse If the washer won't start the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
Line Fuse and Holder If the washer won't start the line fuse might have blown, or the line fuse holder might be damaged and need to be replaced.
Main Control Board If the washer won't start the main control board might be defective. This is not common. Check other parts and causes first.
Door or Lid Latch Assembly If the washer won't start the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't start the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Incoming Power Problem If the washer won't start check to see if there is power at the electrical outlet which the washer is plugged into. Plug a lamp or radio into the outlet to check it. If the outlet is dead, check the circuit breakers or fuses for the hom
Power Cord If the washer won't start, check to be sure there is power to the electrical outlet for the home. If that is OK, the power cord itself might be defective. This is rare. You can check the power cord with an Ohm meter for continuity.
Oct 02, 2012 | Crosley CCW5294W Top Load Washer
My whirlpool cabrio washer #wtw555oxwo won't work. The lid lock light keeps flashing and the washer won't start
Possible that the switch is defective, there is fault in the line to the control unit from the switch of the control unit is faulty.
check these one by one.
Sep 03, 2012 | Whirlpool WTW5550XW Energy Star Qualified...
Washer Control Locked blinking and won't washer won't work
Water still in the bottom of the drum. Empty, clean filter and check pump is turning. Once pressure switch is satisfied no water is left it'll allow the door to open, assuming the door interlock is still ok.
May 19, 2012 | Washing Machines
The "Control Locked" light is
The Control Lock prevents unintended use of the washer. You can also use the control lock feature to prevent unintended cycle or option changes during a cycle. When CONTROL LOCKED is lit, all buttons are disabled except for Pause/Cancel and Start.
You can lock the controls while the washer is operating.
To lock the controls:
Select and hold DRAIN & SPIN for 3 seconds. The CONTROL LOCKED status light glows.
To unlock the controls:
Select and hold DRAIN & SPIN for 3 seconds or until the CONTROL LOCKED Status light turns off.
Mar 31, 2011 | Washing Machines
How do you remove the control lock when "end of
To unlock the controls: Press and hold the End Of Cycle Signal button until the Control Lock light goes Off.
To lock the controls: Press and hold the End Of Cycle Signal button until the Control Lock light comes On.
Feb 12, 2011 | Whirlpool Duet GHW9150P Front Load Washer
The light for the "Control lock" is on and washer will not run.
press and hold the button that reads Control lock for 5 to 10 sec sometimes there is 2 buttons you have to hold at the same time..
Apr 05, 2008 | Washing Machines
Whirlpool Duet GHW9150P Front Load Washer Logo
216 people viewed this question
Marvin
Marvin
Michael Thomas
Michael Thomas
