Heating & Cooling Logo
Posted on Dec 25, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Display is flashing and heat will not come on, tried replacing batteries and still flashing and furnace wont start
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Mar 11, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1144
Points
My furnace doesn't work; my thermostat is flashing a house symbol with the number "2" inside, and a stick figure with a right arrow. What does this mean?
Anonymous
Level 2:
New Friend:
  • Expert 111 Answers
  • Posted on Dec 25, 2010
Anonymous
Expert
Level 2:
New Friend:
Answers
111
Questions
Helped
36281
Points
217
Did you push the little reset button on thermostat?
2answers
Took off back to see filters put back together now wont start. spark,nozzle and fan work it just wont start
My Furnace Won't Start. Any Tips Before I Call for Service?
www.airmasterheatingandair.com/my-furnace-wont-start.-any-tips-befor...
Jan 30, 2013 - When your furnace will not start, you might feel a sense of panic and ... GA furnace repair specialists, our team at Air Master Heating and Air has ...
Furnace Won't Turn On? Furnace Troubleshooting
asm-air.com/heating/furnace-wont-turn-on-furnace-troubleshooting/
Jan 7, 2015 - It can be frustrating when your furnace won't turn on, not to mention ...but when you start moving up north it can be downright dangerous when a ... If your furnace is turning on, but blowing cold air, try: Heater Blowing Cold Air.
How To Fix a Furnace that Won't Start - Bonfe's - YouTube
? 1:52
https://www.youtube.com/watch?v=g5alqU4OvqA
Jun 15, 2012 - Uploaded by bonfesplumbingHVAC
Will your furnace not start? Before you call a professional heatingcontractor, check the following step-by-step ...
Furnace wont start. What to do before calling the repa
Replacing Goodman Furnace B18099-26 with ICM286 fails
decouple the output of the pcb ,put a 10-100nf between the two connectors
My reddy heater pro 100 wont stay lit when i let go of the trigger ive replaced the propane tank
Hello my name is Heath it will be my pleasure to assist you. First thing to do is go to the furnace and look in the small peep hole in the lower blower door and see if there is an led light that is flashing a certain number of blinks record the number and look for a diagnostic chart on the inside of the blower door or the upper side panel of the furnace if there is no flash code present you can try resetting the power to the furnace and see if the furnace will fire up.
On the thermostat the "filter"
Thermostats used in homes sometimes have a timer built in which will remind you to change your furnace filter. Most of them can be adjusted or disabled. The thermostat has no way of knowing whether the filter is actually dirty, it just reminds you every so often by flashing "filter" on the display.
It is possible to reset the timer, or adjust how often it appears, or disable it completely. Exactly how to do that depends on the make and model of your thermostat. Often, it is simply a case of holding two buttons at the same time for a few seconds.
As to why the furnace doesn't come on, there can be many reasons. The problem likely is not the "filter" flashing on the display of your thermostat. Try resetting the breakers that service the furnace unit itself. Make sure that the thermostat is set to "heat" and the setting is turned up. If the thermostat uses batteries (most do these days), replace them.
If this doesn't work, the following information will be helpful to get the furnace running again:
Brand
Model number
Age of furnace
Location in home
Brand and model of thermostat
Rheem furnace problem wont stay lit
You need to see what it does. Does it light at all? will the pilot stay on? If lights but wont let you release the knob then thermocouple is bad. I
If it is electric start then watch the series of events. enducer fan motor starts, element heats up, gas lights but shuts off after 1 second. 5 seconds 1 minute and so on. Also your computer board on the furnace will flash a code indicating a problem. count the flashes and read the panel on the furnace for help it should give a description of the the errors.
all depends on the age and type of unit. respond if you have more questions .
1helpful
We have a White-Rodgers 90 series thermostat that started beeping last night. We have had it for about 4 years. Does it have a battery? I couldn't find anything about that in the manual.
Susan, the "90" series of thermostats covers a couple of different thermostats made by White-Rodgers. Here's how to find your model number. With that info, I can check the manual specific to your thermostat.
In the mean time, check the display for the word BATTERY or BAT. (Flashing) on the display. Battery flashing or blinking on the digital display indicates low batteries. If the batteries have recently been changed and the thermostat continues to indicate low batteries, use a pencil eraser to polish each of the battery contacts inside the back of the thermostat. Do not bend them up and down when polishing or you might break them. When complete, they should all be as shiny as a mirror. This will assure proper battery back-up, allow the backlight to work correctly and remove the flashing battery symbol from the screen. Battery (Solid) on Display The battery symbol (not blinking) indicates a loss of power (24 volts) from the heating and cooling equipment to the thermostat. Normally the heating and cooling do not operate when the battery indicator is on. If the battery indicator is on, check the fuses or breakers, make sure the furnace is switched on, and verify the blower compartment door is closed properly. The battery display is designed to indicate the thermostat is running on batteries, so replacing batteries has no effect on the indicator. See No Heat/No Cool for more information. Note: Some heat only systems (zoned systems) disconnect power from the thermostat during a normal heating cycle and display the battery symbol. Millivolt heating systems always indicate battery because they do not supply 24 volts to the thermostat.
A beep often is provided as audible feedback when keys are depressed on many thermostats. You should check to make sure that no key is stuck in the "in" position or is otherwise activated.
2answers
My furnace wont start from the thermomstat.i have to push in start button on the panel to kick on.. i have my temp set at 70.. i changed the batteries on thermostat.. but every other day i have to go down...
I would say that the thermostat needs replaced! (this is the most common problem with the honeywell brand!
Please rate my response to your question!
THANK YOU!
1helpful
2answers
Thermostat wont turn on heater Robert Shaw 9600 prog.
I have a thermostat 9600 Robertshaw and I have to use the trip switch to start my furnace. Then it reaches the temperature and sometimes it will kick in by itself but majority of the time I have to trip it. I have changed the batteries cleaned the thermostat,and reset it. Is it time for a new thermostat and can I replace it myself. Thanks
2answers
Why Wont My Bryant Furnace Stay Running
Look on the blower door panel in the wiring diagram there should be a flash code but it sounds like the flame sensor is not picking up the flame and you may be able to clean it
Top Honeywell Heating & Cooling Experts
Paul Carew
john h
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
