Hi
The issue is with the control board that is bad and should
be replaced. Before replacing you can also try to take it apart and blow some
air with a hair drier on the board, if the issue returns then replace the
board. Hope this helps...please post back for further assistance.
Daniel
This indicates a failure in the temperature probe. This is easy to check and replace. Here is a link that will walk you thru checking an oven Temperature Sensor .
