Question about Danby DWC283BLS Wine Cooler
My Danby winecooler, the bottom part, white wine part, says "E3" and does not work. That is only after I unplugged it and started it again. Before that it went down to 32 degrees and froze a few of them! What now?
sonic boom electronics
  • 1,557 Answers
Good morning. according to mark rydal the director of dandy inc (publish ny times 22sept 208) there were faulty compressor electrodes fitted to the 283-3400 series yet there is no advice on the fix as a tech i beleve the cause is faulty sensors in the pcb but to date all the paper work i can find on these problems has the owners binning them after having them repaired as the fault re occurs over and over
hope this helps
merry christmas
Posted on Dec 24, 2010
Alarm continuously sounds
According to their manual (http://tiny.cc/winecooler) the only reason that the alarm should be on was already proven not to exist. Call their support number: 1-800-263-2629.
Oct 22, 2014 | Danby DWC153BLSST Silhouette Select 51...
Received apparent error message "E3" for upper
E3 is a fan error. This is usually caused by poor connection to the fan. Remove all connectors and reinstall assuring tight connection. This should remedy it unless the fan is bad, which is very rare!
Jan 12, 2011 | Magic Chef MCWC44DZ Wine Cooler
Wine fridge light does not turn off
You may know this already, but for what its worth. There is a small switch on the bottom vent grill for on/off of light. Check there first.....
Nov 27, 2008 | Danby Silhouette DWC512BL Wine Cooler
I want to switch the door swing on a danby wine cooler.
Yes, according to the manual, the other hinge was supplied with the unit. The phone number to Danby Support is 800-26-Danby.
They can get you to a supplier for the part.
v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
Nov 18, 2008 | Danby DWC283BLS Wine Cooler
Returning a Danby Winecooler
This unit was purchased in West Hollywood, CA on LaBrea.
May 30, 2008 | Danby DWC283BLS Wine Cooler
Winecooler danbydwc2121bls
I have a unit similar, I am replacing the control board and related parts - basically the electronic and electrical parts in the area the separates the two sections
May 18, 2008 | Danby DWC283BLS Wine Cooler
I want the bottom to be reds and top to be whites
I don't think you'll be able to do this without some modifications to the unit.  The wine cooler is designed to blow cold air into the bottom section, and the top section cools down by spillover of cool air flowing between the glass door and the temperature control panel.
I guess if you could figure out a way to turn the panel that separates the top from the bottom you could make it work.  You'd have to switch the temperature sensing leads on the thermostat inside that panel(that would be pretty easy) and you'd probably want to flip the LED indicators so they read right-side-up.  The main issue would be that the screw holes for mounting that separator panel are all on the bottom, but when you flipped it, they would be on top with no holes in the walls to screw them into.  If you are willing to do that, you might be able to make it work as you would like.
Good Luck!
Dec 27, 2007 | Danby DWC283BLS Wine Cooler
Danby DWC283BLS Wine Cooler - Error message E3 & E4
Is the compressor running? I don't know this unit, but know that if you are too warm that is the first thing to check. In reading about another unit that had a different problem, it was mentioned that there is a ciruit board. If it has relays on it then these are the most likely culprit. They are either not making contact or staying in contact too long... sometimes just tapping each relay usually a black plastic component will cause it to work intermittently..Not sure if you can get these but call the company help line at 1-800-263-2629.
Jun 12, 2007 | Danby DWC283BLS Wine Cooler
Danby DWC283BLS Wine Cooler Logo
106 people viewed this question
Top Danby Furniture Experts
Dennis Boxerman
Marvin
Marvin
Are you a Danby Furniture Expert? Answer questions, earn points and help others
