Remove the top half of the tube so that you can see the blower. Try to turn it by hand to see if it is tight. If it is tight, you may be able to oil it a little and get it to spin easier. Another thing to check would be the compressor attached to the back of the motor. There are 3 screws that hold the filter cover on. Remove the filter cover. Next, 6 screws hold the cover on the compressor. Remove that cover also. Inspect the rotor for damage and make sure the 4 fins in the rotor move freely. With the compressor cover removed try turning the fan to see if it turns easy. Be careful not to let the fins fall out of the rotor. Now put the cover back on the compressor and turn the fan again to see if there is any difference from when the cover was removed. If it doesn't turn freely once the cover is reinstalled then the problem is in the compressor and you need to figure out where it is rubbing. If it is in the motor, you will probably need a new motor.
Here are a couple of tips that I
wrote that tell you how to troubleshoot a Torpedo or Reddy
heater...
Reddy
Heater - Troubleshooting Torpedo Heaters
Torpedo
Heater Pump Pressure Adjustment
heatman101
