Question about JBL S120PII Subwoofer
How to set up to stereo ? - JBL S120PII Subwoofer
Posted by ozzy617 on
Vito Vacirca Jr.
  • 140 Answers
Generally there is a left and right input. The sub is usually not in stereo, the frequences of the sub are more omni directional, and have no spattal placement in the stereo field. If there is only (1) input you can take either the left or right from the system and you should get the frequencies you need. In the even it is not working out quite right you may take the left and right and use some 1k to 4.7k 1/2 watt resistors connected to tie the left and right line output togeather to feed the sub.
Posted on Dec 24, 2010
I am having problems getting these wireless rear speakers and receiver to sync to the stereo system
Is your stereo system set up for wireless communication? If it is, you may have to go into the user manual for the stereo, to find the setting for it. The wireless setting may be set to off by default.
Feb 22, 2013 | Audio Players & Recorders
Hello...I have an issue with my speakers. My husband ran our speaker wires from our computer to our stereo and I can't get it to produce sound please help!!!
Be sure you plugged the plugs into the right ports on the back of the stereo.
From the computer: ensure you plugged the cables into the Auxilary Out, or Out jacks of the sound card.
On the stereo: ensure you plugged the cables into any open set of Auxilary In jacks.
Once you verify your cables are plugged in correctly, verify the input on the stereo is set properly. Set your stereo's source or input to "Auxilary" or "Auxilary 1 or 2." This allows the stereo to pull input from the cables running into the appropriately selected Auxilary source.
That should help hopefully.
If you still can't get sound, double check your computer's sound card settings and be sure the sound card is working properly.
Jan 10, 2011 | YouTube Videos
Stereo does not store adjusted audio settings and restarts after being turned off
Check to make sure the yellow from the stereo harness is connected to constant battery, connected to the battery, when the ignition switch is off, the yellow wire still has power. The yellow wire is for the memory for the stereo settings and radio station presets.
May 16, 2010 | Car Audio & Video
I have a rca truflat tv 27F522T how do i change it from mona to stero
This is a stereo TV:
From the manual:
Stereo Capability: Includes built-in amplifier twinspeaker
system; allows reception of TV programs
broadcast in stereo.
Use a stereo cable
Sep 17, 2009 | RCA TruFlat 27F520T 27" TV
Setting the clock on my damn stereo
Pioneer stereos clock setting
1)turn car iginition "ON"
2)turn stereo ON and then OFF.
3)Press SRC or Joystick until blinking clock appears
4)Set clock by pressing rt,left &top,bottom keys around volume knob (joystick).
i hope this helps.
Apr 18, 2009 | Car Audio & Video
Zune problem
ok first off, you need to set your stereo system to aux....remember aux the zune is not a cd player.
depending on the brand of stereo system there is a setting were you can change it from cd, to radio and AUX. SET IT TO AUX
do you have a stereo head phone jack on your stereo system, if you do a much better solution is getting a double sided audio cable and plugging the zune directly into the head phone jack to your stereo system it costs maybe $10 for a good gold plated phillips
what i mean just incase you didnt understand is you need a double sided plug for the headphone jack, this plugs into most stereo systems
Mar 31, 2009 | Microsoft Zune JS8-00001 Digital Media...
V551 and Bluetooth car stereo
the phone itself is having a problem connecting fully with the pioneering car stereo you may need to use a motorola one
May 15, 2008 | Motorola Mobility V551
Helo i have got a nokia 5300 black express music phone and i brought these mobile phone twin music speakers for them but i dont know how to set them up so please can u help me thnks
Equalizer
You can control the sound quality when
or diminishing frequency bands.
Select Menu > Fun & Apps> Media > Equalizer.
To activate a set, scroll to one of the equalizer
To view, edit, or rename a selected set, select
Not all sets can be edited or renamed.
Stereo widening
Stereo widening enhances the audio output of the phone by enabling a wider
stereo sound effect. To change the setting, select Menu > Fun & Apps>
Media > Stereo widening.
Mar 25, 2008 | Lands Phones
Old jvc home stereo
FM stereo will need a good aerial to work properly, but AM doesn't. If you have not got a good aerial, stereo will stay off. Though you might still here the station. It needs a lot of signal to make the stereo light activate. If was to come on in the weak state the sound would be full of interference. So the set keeps it switched off.
Oct 05, 2017 | Audio Players & Recorders
JBL S120PII Subwoofer Logo
57 people viewed this question
Top JBL Audio Players & Recorders Experts
 Grubhead
Grubhead
Bob Kirkwood
Are you a JBL Audio Player and Recorder Expert? Answer questions, earn points and help others
