Admiral 24 in. DDB1501AWW Free-Standing Dishwasher Logo
Ruby Shen Posted on Dec 24, 2010
The door is locked and can't be open. - Admiral 24 in. DDB1501AWW Free-Standing Dishwasher
1helpful
2answers
I have a 2000 chevy astro. All my doors lock and unlock except the two front doors. And my key fob won't lock or unlock any my doors. But the panic button still works,strange. Anybody else ever had an...
Service repair info. manual would be the place to start ,seeing how you have no clue .,or maybe a qualified repair shop. How are you going to fix it with out knowledge of how it works an what to check , --------------------------------------------------------------------------------
Power Door Locks Circuit Description
The power door locks are operated by reversible motors. The motors are found in the following locations:
• In each front door
• The side door
• The rear door
The PWR ACCY circuit breaker (30A) supplies voltage to the door lock motors.
If you move either power door lock switch, mounted in the front doors, the LOCK applies voltage to cavity F of the door lock relay. This energizes the lock coil in the relay. Current then flows through CKT 295 (GRY) directly to the following components:
• Both front door lock motors
• The side door lock motor
• The rear door lock motor (cargo doors only)
CKT 246/294 (TAN) provides the ground for the motors. The normally closed contacts of the UNLOCK then contacts the door lock relay.
If you move one of the door lock switches to UNLOCK the polarity of the system reverses. Current flows through the energized UNLOCK relay contacts. The LOCK relay contacts provide ground.
When the UNLOCK button is pressed once on the RKE transmitter, only the driver door unlocks. If it is pressed a second time within 5 seconds, all doors unlock.
If the side door is open, the side door jamb switch ground signal is opened/broken. If you move the door lock switch to LOCK while the side door is open, the following actions occur:
• The 2 front doors lock
• The rear door locks (cargo doors only)
When you close the side door, the door jamb switch closes. This closes the ground signal to the body control module {CKT 775 (PNK)}. A 5 second timer then starts in the module. After 5 seconds, cavity A4 connector C1 of the body control module supplies voltage to the door lock relay via CKT 195 (LT BLU). This energizes the door lock relay, which sends voltage to the door lock motors in order to lock the side door. Refer to Door Jamb Switches, Liftgate Strut Switch for a schematic of all door jamb switch inputs.
If the side door opens during this 5 seconds, the 5 seconds timer is reset. The locking pulse takes place at the end of the 5 seconds. Unlocking the door resets the 5 second timer in the body control module.
Use the following components in order to unlock the door lock system:
• The LH power door lock switch
• The RH power door lock switch
On vehicles equipped with cargo doors, the cargo door opener mechanically opens the door once the door lock system is unlocked. On vehicle equipped with a liftgate, the liftgate lock/unlock release switch (mechanical key) is added in order to serve the same function as the front power door lock switches. These functions locking and unlocking all doors, including the liftgate. Once the door lock system is unlocked, press the liftgate release switch in order to electrically open the liftgate and pull the handle in order to open the secondary latch.
How can I lock a renault megane 56 plate without the key card as it is not working
Locking/Unlocking the doors from the outside
This is done using the RENAULT Card; see the "RENAULT Card" information in Section 1.
In certain cases, the RENAULT card may not work:
- if the RENAULT card battery is weak, flat, etc.
- if equipment operating on the same frequency as the card (mobile phones, etc.) is used;
- vehicle located in a high electromagnetic radiation zone.
It is then possible:
- to use the key integrated into the card to unlock the front left-hand door;
- to lock each of the doors manually;
- to use the interior door locking/unlocking control (refer to the following pages).
Using the key integrated in the RENAULT card
Insert key 1 into the lock in the driver's door and lock or unlock. Locking the doors manually
Turn screw 2 with the door open (using the end of the key) and close the door.
This means that the doors are then locked from the outside.
The doors may then only be opened from the inside or by using the key in the front left-hand door. Interior locking/unlocking door control
Switch 3 controls the doors, boot and, depending on the vehicle, the fuel filler flap simultaneously.
If a door or the tailgate is open or not closed properly, the doors and tailgate lock/unlock quickly.
If you need to transport objects with the boot open, the other opening elements can still be locked: with the engine stopped, press switch 3 for more than five seconds to lock the other opening elements.
Locking the doors without the RENAULT card
For example, in the event of a discharged battery or the RENAULT card temporarily not working, etc.
With the engine switched off and an opening element (door or boot) open, press and hold switch 3 for more than five seconds.
When the door is closed, all the doors and the tailgate will be locked.
Unlocking the vehicle from the outside is only possible with the RENAULT card in the vehicle's access zone or using the key integrated in the RENAULT card.
Door and tailgate status indicator
With the ignition on, the warning light integrated in switch 3 informs you of the locking status of the opening elements:
- indicator light on, the doors and tailgate are locked,
- indicator light off, the doors and tailgate are unlocked.
When you lock the doors, the indicator light remains lit and then goes out.
1helpful
How to open a deadlocked rear door.
Hi. remove the rear seat and door pad. You can access the lock through a small hole, break the top inner corner of the lock and it will release the dead lock and open the door.
Vw golf mk4 my rear passenger door willnot open with central locking key system. i can't even open it from the inside, pull the door handle and the lock pin rises but door won't open. i believ
This worked for me on 2008 Mk5 Golf, after the rear passenger door would not open fro outside or inside.
Hold the inside door latch open and keep it extended, then with the key fob open and close the door locks (still holding the inside latch open). Keep locking and unlocking the door, then it made a kluck and it released.
Right rear child lock is on the door but cant get the door open
Child Locks will stop anyone on the inside of the car from opening the door. If the child lock is on then the door can only be opened from the outside of the car. Of course the main door lock must be off just as any door must be unlocked to be opened from the outside.
Now if you do not want the child door lock to be on then you must first open the door from the outside with the main lock open or unlocked. Look at the space that is covered when the door is closed. There you will see the lever that turns the child lock on or off. Simply move it to the off position.
Good Luck.
Back door will not open at all 1994 infiniti j30 how can i get it open tried to take off panel not enough room any solutions need help
Did you check to see if the child safety lock may have been activated? If so the door will only open from the outside.Try removing the power door lock switch/arm rest assembly to see if the door lock switch can be jumped out in the event the door lock switch is burnt out.
Does the Infiniti have an exterior key lock cylinder on the rear door? If so try to get a key to open the lock, it may be very difficult to remove the door panel when the door is sealed closed, but if you can that may be your only salvation short of attemting anslim jim door opening tool down the side of the door glass in ho[pes to trip the door linkage lock thus opening the door.
1helpful
Central locking
turn key twice when opening, ie turn right. once drivers door will unlock, turn twice passengers doors will unlock, and locking is turn anti clock wise once will lock all doors, turn twice will set door dead locks.dead locks will stop openand lock internal button working and handle from opening door. the same actions can be applied to the remote one press drivers door, two press passenger doors, press and hold unlock button for 5 seconds and rear window will open.
1helpful
Door Lock?
this is not a problem, it is a feature. its purpose is to try and make it harder to lock your keys in your car. try this: with the door open, pull the inner door handle like you are opening the door. with the handle pulled, lock the door. it will lock.
Back door wont open.
Are you moving the child safety lock or the door lock? Only the door lock itself should prevent the door from being opened from both inside or out. The child lock is typically a switch on the door near the door pin halfway down the door.
Door locks problem with one door drivers door
dont blame the idiot,we all make stupid mistakes without thinking and iam no exception,remove door trim and oil the solonoid with a oil can not a silly sunday mechanic spray and let it soak in as its working but i think its just a bit sticky with wear and dirt ingress hence it locks but doesnt unlock which might need a bit more power,oil the whole lot lock and all
Top Admiral Dishwashers Experts
Paul Bade
john h
Bonded Repair
Are you an Admiral Dishwasher Expert? Answer questions, earn points and help others
