Question about GE GSH25JFR Side by Side Refrigerator
Gsh25jsrf side by side ge it is making a buzz clic clic from the back buzz from compressor clic from circuit board came back on after spinning the fan worked for a night then back to noise and not working
Posted by two_shepherd on
fixrguy
  • 415 Answers
It sound like the compressor is overheating and the start relay could be failing because of the holiday and possible not getting a tech out there, pull the frig out from wall and remove the back panel and get an portable fan and let it blow air on compressor to keep it cool, If you here the sound on the covered axcess panel on the back the mother board is questionable. Hope this helps....
Posted on Dec 24, 2010
S by s has frost build up Model # GSH25JSRF-SS
You will have to check the continuity of the defrost system. You can check this by unplugging refrigerator, and testing the circuit from the main control board behind the refrigerator. If the circuit is not compromised, the problem is likely with the control board itself. If the circuit is not intact, you will have to open up the freezer and test all the individual defrost components. There are thermostats and thermistors that need to be tested in cold conditions, in other words, you will have to test them while there is frost on the evaporator. You can however test the defrost heater with or without frost on the evaporator.
If you have further questions, visit my website and send me a question. www.FixMyFridge.net
Mar 16, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
GE model GSS22JEMDWW. Replaced the compressor six
check the RTX overload on the compressor body its bad and trying to start the compressor
Dec 14, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Model GSH25JSRF SS is clicking non stop, the click comes from a small panel on the back right of the fridge. Started out that the water and ice dispenser didn't dispense. Then the clicking just came...
Is it still cooling? I had an issue where there was a clicking noise from the back panel and the fridge did not cool. Pulling off the panel the noise seemed to from a box on the circuit board. Turns out there was a problem with the controler board and after some research I found that the board was covered under a recall. GE ended up sending a guy out to replace the board at no charge. Pretty cool being that if was after the warranty had expired; but I guess it makes sence since there was a recall. Good luck.
Dec 10, 2009 | GE GSH25JFR Side by Side Refrigerator
Fridge not cooling, freezer not freezing even on coldest settings
From what you are describing, you have a refrigerant leak. The freon has leaked from the system, The compressor will still run and evrything looks fine. To double check you will have to have someone hookup gauges to the system and verify that the charge is lost.
It may be possible to find and repair the leak. This is not always possible as some of the system is virtually inaccessible in many refrigerators.
Make sure if you do have someone repair the system that they evacuate the system very well and do a good vacum test before recharging the system.
This should help you to solve your problem.
Thanks for using Fixya!!
Heatman101
Nov 23, 2009 | Refrigerators
GE PSS25MGMCAA refrigerator - Bad circuit board??
You need to change the board . Part number WR55X10656 . The board relay , cannot be changed . Power surges , dirty condensor coils , and usage , are the most common causes , for board failure .
Sep 23, 2009 | GE Refrigerators
Freezer fan noise
Remove the freezer panel to access the fan motor. Look for any obstruction around the fan or blade. Ice, misplaced wire etc.
Check the fan blade. Sometimes they slip down the shaft too far.
If you find none of these issues, replace the fan motor.
May 25, 2009 | GE GSH25JFR Side by Side Refrigerator
I have a GE profile refreigerator model PTS25LBMARWW. It started to defrost in the freezer. I have working knowledge of refrigerators as I completed A/C and refrig. trade school 20 years ago. here is the...
Make a insulated jumper wire.
Remove the circuit board panel.
Jump the line in side with the compressor terminal.
On the bottom of the control board you will see a molex connector with 3 wires. That is where you will see the 3 terminals.
If the compressor and fan motor come on after the jump.
Replace the control board.
Mar 10, 2009 | GE Refrigerators
My ge side by side refrigerator has stop coolin on both sides
The clicking you hear is most likely the compressor trying to cycle. It sounds to me like you are low on refrigerant. Most are thermo. protected and will not run on low coolant. Frigerators DO NOT make cold, they absorb heat from inside the box and expell it out the back. Most common cause of refrigerant loss is a leak, usually near the compressor. Hope I Helped
Mar 08, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE MODEL GSH25JSRF-SS PROBLEM HELP PLEASE
I had the same problem back in March. First the water and ice dispensers stopped working, then the clicking started and the compressor wouldn't turn on. I replaced the circuit board and everything started working again, until today. This is a very common problem with the circuit board on these refrigerators. Do a search for "GE circuit board" and you'll see what I mean. GE issued a service bulletin to its technicians that this service should be provided free of charge, and anyone who already paid to have the circuit board replaced will be reimbursed. I wish I would've known about it 6 months ago. I will be calling GE Consumer Affairs on Monday to get this resolved.
Jul 26, 2008 | GE GSL25JFPBS Side by Side Refrigerator
GE GSH25JFR Side by Side Refrigerator Logo
133 people viewed this question
Top Refrigerators Experts
gbob59
Marvin
Marvin
