The blinking light is typical of a failed lamp and they last commonly between 2-5 years tops in these sets. You should replace the lamp. The link below is to the lamp for your set.
well to be honest with you it could happen if you purchase a generic bulb they will only last around 1year to 1.5 years always buy Philips the other problem that you may have could be the ballast board if for any reason it is sending to much voltage to the lamp it will make the lamps burn out much faster If you want to fix this problem I would replace the ballast board ( around $60.00dls - $80.00dls) and also replace the lamp ( $115.00dls - $140.00dls ) this store has the Philips lamp
Lamp replacement procedure is written in user manual of tv in details, click Sony Support to download user manual copy that will help you to replace lamp. Thanks.
Try connecting the TV directly to a different wall outlet and check. If the issue persists, try power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue persists, then the TV requires service.
Hi, Yes, its clear symptoms of weak lamp that is going to end of its working life, soon tv will show you lamp light. Replace lamp to solve the issue, lamp replacement procedure is easy and written in user manual. Please buy Sony original lamp for good picture in tv. Thanks.
