SOURCE: i have a hp pavilion dv9700 notebook pc, it can
it is likely that your dvd is defective. I would suggest removing it and ordering one on ebay once you have the model number. They are fairly easy to remove. one screw holding it in either on the bottom of the laptop or under the keyboard
SOURCE: HP 530 Laptop CD/DVD Drive Not Working
Please buy new CD/DVD drive since it wont open you cant event check using media. Its a possible mechanical failure.
Testimonial: "Thanks that really helps"
SOURCE: hp 530 notebook will not charge
Try starting the laptop with no battery inside and only the power adapter connected. If it does not start , then you have a faulty dc adapter, or the socket on motherboard has a broken soder joint.
If the laptop starts with DC adapter, then usually you have a faulty battery. There are a couple of other faults on battery charger circuit, but they are quite uncommon.
