Question about Dacor ECD227 Epicure Electric Double Oven
I have a Dacor double oven that gives a error message of F0 and then shuts itself off.I don't have the manual so I don't know what this error code means or how to fix it.HELP!
Posted by nanaof2 on
Anonymous
    Problem Solver:
  • 15 Answers
F0 means shorted keypad or stuck key on keypad.
Solution: The membrane aka keypad has to be replaced.
There's a slight chance that the ERC aka oven controller is acting up also.
So safest bet replace both, ERC and membrane.
Posted on Jan 12, 2011
Double wall oven F0 error code
The F0 error code means that the control board has detected a defect within the control board itself, the F0 code can be cleared by pushing the CANCEL/OFF button and if it goes away and returns all is well,however if a short time later the F0 returns the control board would need to be replaced.
GENE
Oct 04, 2011 | GE Profile 30" Built-In Double Electric...
Dacor model ersd30 how do i fix an F0 error code that also blinks F1 and beeps
Hi dan8260,
If you're encountering F0 error code, it is due to a stuck function key. You need to replace the touch pad to fix this error. If the touch pad is part of the clock, you need to replace the clock or ERC.
Hope it helps.
Thank you for using FixYa.
Feb 07, 2011 | Dacor Epicure EO127 Stainless Steel Dual...
We have a dacor double oven that is not running and keeps giving us error message of F1.. Neither of the ovens will work.. Any idea what is wrong and how to fix it?
Hello & Welcome to FixYa
Error code F1 is displayed due to electronic oven control failure and the only way to solve this problem is by replacing the control board which is bad. Please get back to me if you have any other questions.
Kevin
Feb 03, 2011 | Dacor Ovens
A code appears on my Dacor oven/stove that reads FO, what does it mean?
Hi bevtrust,
The error code that appears on your Dacor oven is about a stuck function key which refers to F0 error code. To fix this problem, you need to replace the oven's touch pad. If the touch pad is part of the clock, you need to replace the clock or ERC.
Hope it helps.
Nov 16, 2010 | Dacor Epicure EO127 Stainless Steel Dual...
Dacor 48" range, double oven. ovens do not work. Letters FO appear on the display. Any suggestions?
F0 means: Clock pushbutton is stuck in a depressed position. Check clock buttons. You might need a new touch pad.
Dacor range repair in orange county, ca
appliance repair orange county, ca
Feb 07, 2010 | Ovens
GE JT912-30 single wall oven "help" with F7 - F0 error
I have a double oven GE Profile. The error message FO appeared. I shut off the circuit breaker for 30 minutes or more and the oven works but without warning FO reappears. FO message means there is short in the clear Off touch button. The only solution replace the complete panel. My cost delivered $328. Ouch!
Jan 19, 2009 | GE Profile JKP56 Electric Double Oven
F0 error code on GE Profile PT956 double electric oven
you can also put a piece of paper between the ribbon cable where it joins up before the connector. It has been reported that the cable will short in this area. Try that before spending more money since most of the F-codes appear to be cable related.
Dec 01, 2008 | GE Profile PT956 Electric Double Oven
Display 11
your control must be fried...dacor fault codes are f0 to F8 the display must be faulty..
Aug 25, 2007 | Dacor ECD230 Epicure Electric Double Oven
Error codes on my Dacor Range -
Both of those codes suggest a bad membrane switch assembly. i dont specifically remember what the f1 error is, but the f0 error is "stuck membrane button" The membrane switch is just the touch panel, and usually run in the mid $200 range for the part. Its fairly easy to change, just label all your wires when you pull em off so you know what direction they go in. some of the connectors CAN BE put on backwards, so just make a good diagram or whatever to get em right. Good luck!
Jun 17, 2007 | Dacor ECS130 Epicure Electric Single Oven
Dacor ECD227 Epicure Electric Double Oven Logo
339 people viewed this question
Top Dacor Ovens Experts
Paul Bade
Vincent G
Vincent G
ray gallant
Are you a Dacor Oven Expert? Answer questions, earn points and help others
