Question about Nokia 5310 Cellular Phone
My nokia 5310 fell down and volume control is not working.. i am not able to adjust the volume.. how can i make the volume control work.. or how can i increase or decrease the volume without using volume control.. please give me a solution.
Posted by sakthe_sam on
Vignesh V.T
  • 323 Answers
Hi
either your volume button get damaged or the software gets corrupted in your phone.. change the volume button and format the phone.this willl fix your phone..
thank you
Posted on Dec 24, 2010
I cant increase or decrease volume on my nokia 5310 xpressmusic. What can I do?
If both the volume does not work there is no other way.The only thing we have to do is to change the Pata(Flex).So, contact mobile repairing shop Or refer the image raingamj_31.jpg
Thanks for visiting fixya
Aug 06, 2011 | Nokia 5310 Cellular Phone
I can't able to decrease the volume but i can increase the volume
c, when u decrese the volume, then volume level appeares on screen. That time, simply press up key. Volume will increse.
Jun 09, 2011 | Nokia 5310 Cellular Phone
My nokia 5310 handset volume is not working.
sir when you answering the call then increase the volume button to increase the volume of the handset
Nov 23, 2010 | Nokia 5310 Cellular Phone
I have nokia 5310 mobile in my mobile my volume slider button is not working so i can't increase my volume the audio is so tiny.
i have nokia 5310 mobile xpress music, once i remove the memory card and inserted, now it's asking password but i din't remember of setting password for memory card, pls help me on urgent basis or re-direct to correct party to liaise with..
Regards, Asha
Oct 06, 2010 | Nokia 5310 Cellular Phone
Buttons not working
The volume key is stuck that's why the volume bar keeps on popping out. It is also the reason why the keypad is not working. You have to unstuck the volume key to check if the keypad really doesn't work.
  1. Remove the battery cover and battery.
  2. Remove the camera cover by prying the locks along its sides and lifting it up to expose the volume keys.
  3. Insert a needle between the volume key membranes and the board to unstuck it. The membranes should click when pressed.
  4. Install the camera cover in reverse order.
Inform me if the volume keys work fine but the keypad buttons don't.
Jan 01, 2010 | Nokia 5310 Cellular Phone
Nokia 5310 won't send or retrieve MMS messages or connect to web
Nevermind! I found the solution. You just have to go to nokia.com and choose your phone and you can have them text the MMS and web settings directly to your phone and then you simply save the settings and after I did this, no problems. Works like a charm now! Stupid AT&T customer service.... Grrr.
Nov 18, 2008 | Nokia 5310 Cellular Phone
Nokia volume
Hi.  I had a similar problem but only the down volume buttonw worked (which meant that my volume was at 1 but I couldn't get it to go any higher).  If you are able to use one of the volume buttons, press it once to take you to the voulme control screen; then use the centre button to conrol up and down using left and right.
Jun 27, 2008 | Cell Phones
Volume control
WELL you place the call press send wait for connection and then use the up arrow to contro volume...sound simple well it took us a heck of a long time to figure this out HOPE THIS WORKS FOR YOU
Oct 31, 2007 | Nokia 6233 Cellular Phone
Nokia 5310 Cellular Phone Logo
998 people viewed this question
Top Nokia Cell Phones Experts
Muntejaya Ginting
Muntejaya Ginting
Zaid Anarwala
Zaid Anarwala
SANTHOSH
