Question about Evenflo Babygo Portable Playard With Changer and Bassinet
Side rails will not lock - Evenflo Babygo Portable Playard With Changer and Bassinet
Posted by shopkins13 on
Anonymous
    New Friend:
    Problem Solver:
  • 18 Answers
  1. 1 Visit evenflo.com and click on the "Product Instructions" tab located on the bottom of the window. The next page will list replacement parts. An instruction manual is considered a replacement part.
  2. 2 Enter the model number and date of manufacture for the Evenflo BabyGo item for which you need the instructions. You can locate the model number and date by looking for a sticker on your item. If you need help locating the sticker, visit evenflo.com and find the type of equipment and the site will tell you where the sticker commonly is located. If you cannot locate this information, skip to Step 4.
  3. 3 Select the instruction manual for your EvenfloGo equipment. Some manuals will be available for immediate download, while for others you may have to input your information to include your address and Evenflo will mail you an instruction manual at no charge.
  4. 4 Call Evenflo customer service at 1-800-233-5921. Give the agent as much information on your product as possible so that the agent can locate the correct Evenflo product. Ask the agent to provide you with a download link to the manual if this is your preference and if it is available, or ask the agent to mail you the manual.
Read more: Evenflo Babygo Instructions ' eHow.com http://www.ehow.com/how_7191269_evenflo-babygo-instructions.html#ixzz1B8cEnLxp
Posted on Jan 15, 2011
  • Anonymous Jan 15, 2011
    hope this helps
How do you lock an Avalon on the move series playpen? Where do I get instructions?
  • These playpens have a safety feature.
  1. First thing is to make sure the center of the playpen is up in the air.
  2. First lock the short side rails. They will click into place.
  3. Now lift up and lock the long set of rails.
  4. Now you want to push the center piece (floor) down all the way.
  5. Now your playpen is set up.
  6. When you go to put it up you will pull the floor up first and then release the side rails.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Jun 17, 2011 | Baby Gear
Only the left side of the drivers side seat moves when you try to adjust the seat forward or backward
You don't idicate whether it's a power or manual seat. Assuming it's a manual seat there is a link between the rails under the seat. It can become disconnected preventing the right rail lock from unlocking.
Apr 14, 2011 | Chrysler Concorde Cars & Trucks
Cant lock the end rails of the porta-cot, the two side ones lock in fine but the end ones just fold back down. Its a Jeep Sahara Limited XT playland.
Before you lock the bottom of the playard, you need to pull all the way up on the two side rails, they will form a slight arch, and the button will click into place. Then push down on the bottom rails.
Feb 06, 2011 | Kolcraft Jeep Sahara Limited Xt Playard
How do you put up a graco pack play
Hi, to set up the pack and play, first latch each of the four sides together. (Each side rail latches together in the middle -- just straighten the rail.) Once all four sides are locked and straight, push down on the center of the pack and play bottom (it's probably red) until it snaps into place.
To fold the pack and play up, just follow these instructions in reverse -- pull the bottom up first, then press in the button on each side rail to fold up each side.
Always make sure the pack and play is completely set up and locked before putting a child in it!
Aug 02, 2010 | Graco 9445DOH Crib
How do you set up a pack and play?
Open it part way but do not push the center of the bottom all the way down. Raise each of the side rails and make sure they lock in place in the full up position, When all four side rails are locked in place, push the bottom center all the way down until it locks. Put the the bottom pad in place and secure it with the velcro tabs through the opening in the sides.
Jul 06, 2009 | Baby Gear
Trying to open my combi playpen
lock the side rails up first thing before you do anything else. make sure the bottom is all the way up, then lock sides spread feet apart and push down in center
Apr 10, 2009 | Baby Gear
Directions to set up a pack n play crib
you have to pull the sides up and lock them before you push the bottom down
Dec 27, 2008 | Baby Gear
Trying to take my cd drive out and put in a new one but the old one will not slide out and I do not see any screw that need to be removed
If it is a normal PC, there should be 2 screws on either side of the drive that have to be removed before the drive can come out. Many times you have to remove both sides of the computer case to get to these.
This can vary however from manufacturer to manufacturer. Some put the drives on what are called rails where, if you release the rail it will simply slide out, other times only one side has screws.
If it is a mass manufactured PC (DELL, Gateway, HP, etc.) you should be able to find a manual on their site that would help.
Sep 21, 2008 | Acer Computers & Internet
Kinderkraft crib model 710
On the bottom of the front rail that drops (the drop rail), there are two plastic tension pieces (one at either end) that engage the two fixed, bottom rail slider hardware (the long, narrow pieces screwed top-and-bottom into the lower, inside portion of the tall, upright crib ends). These tension pieces are spring loaded, and the outer edge of each one rides along the outside (i.e., the parent's side) of the two bottom metal rail guides. Their purpose is to supply outward pressure against the lower part of the drop rail - that's what you push against when you press your lower leg upon the bottom of the drop side of the crib to lower it. They insure that when up, the drop side locks safely into place. I suspect these tension pieces are your problem. It sounds like they are improperly installed. Good luck.
Sep 10, 2008 | Kinderkraft Vermont Crib
Crib locks
if you're missing the lock parts from the ends of the side rails(end caps), I was to. I borrowed the cap from the youth bed rail
since when it's configured as a crib, that rail is extra anyway.
when it was time to go with the youth bed I simply put the end
caps back onto the other rail. GOOD LUCK!
Apr 10, 2008 | Childesigns Carrollton Crib
Evenflo Babygo Portable Playard With Changer and Bassinet Logo
883 people viewed this question
Top Evenflo Baby Gear Experts
Ekse
Lee Hodgson
Lee Hodgson
Colin Stickland
Colin Stickland
Are you an Evenflo Baby Gear Expert? Answer questions, earn points and help others
