Question about Proton MS-32 TV
I cant turn on the tv - Proton MS-32 TV
Posted by hector_gu37 on
Dehancy Barney
    Master:
  • 691 Answers
Any LED lights, if none or comes on then go off suspect Power supply board
Posted on Dec 24, 2010
I have telefunken tv and whene i start it the picture come but it block i cant move anything i cant use the remote i cant even close the tv just if i Unplug the power pls helpe me
I'm not quite understanding what exactly you are saying. Do you mean,
You have a TV, and when you turn it on, you have pictures but, you can't scroll or operate/change channels, volumes etc. by using the remote but, in order to turn the TV off, you have to unplug the power cord.
1. Check the battery in the remote
2. If the battery is good in the remote then you might have a bad remote, buy new remote or replace it with a universal remote.
3. If either not a battery or remote, then it will be the control board inside the TV quit working and will need to be replaced. Depending on how expensive or age of the TV. By the time you invest fixing the board with labor, might runs you from $200 to $400 bucks, and you can buy a new TV from Walmart a 49" inch TV for $319 bucks.
Jul 30, 2018 | Televison & Video
Hd-56g647aa jvc tv theres a tv lock code kids got ahold of the tv remote but the lock comes up all the time and cant watch tv for longer then ten-fifteen minutes screen turns black and tv locks ive been...
Hi Anthony
Please try to go on the tv lock code features, may be you were able to set time. You just mention that 10 to 15 mints your tv will turn to black and then lock. You need to off the setting.
Jan 16, 2014 | Televison & Video
My television can't switch on
have you tried turning the tv off for 4 to 5 hours unplugging it
Jan 13, 2014 | LG 47LM6200 - 47" Class LED 3D Cinema HDTV...
How do i turn off the TV audio
Go back to the initial setup procedure. You'll find that option listed.
Nov 30, 2013 | Sanyo DP37647 37 in. LCD TV
I cant find remote for 52" Bravia tv. Can I turn
Yes, you can turn it On-Off by pressing power button on side of tv.
Required tv remote for KDL-52W4100 is available at Remotes.com
Hope these info will help you.
Thanks.
Nov 05, 2010 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
I cant ge the tv to turn on. When I press the
go to the tv and try if i dont work try to unplug your cablebox
Feb 06, 2010 | Sony RM-Y914 Remote Control
Cant turn off panasonic PIP
To turn off the "stuck" pip on a Panasonic tv without a remote, turn off the tv. Then hold down the "Action" button on the front of the tv and press the power button. This will activate a reset and self check of the systems and voila! The pesky pip screen will be gone! This is on an approximately 10 year old regular crt "CT-xxxxx" series tv.
Jun 12, 2008 | Panasonic CT-36D32 36" TV
Cant turn on my tv
There's a short in there somewhere. Have a pro look at it.
Mar 25, 2008 | Panasonic PT-43LC14 43" Rear Projection...
New vizio tv cant get remote to turn tv on
same problem
but it does turn on with a remote.
no other functions
i'ven repl. power supply brd. no help.
i do not hear relay click on
it seems to be in the main brd.
thank you
zbyg
Dec 19, 2007 | Vizio L37 Television
Open Questions:
See all Proton MS-32 TV Questions
Proton MS-32 TV Logo
47 people viewed this question
Top Proton Televison & Video Experts
matt martin
matt martin
ray gallant
Are you a Proton Televison and Video Expert? Answer questions, earn points and help others
