Garmin nuvi 780 GPS Logo
Posted on Dec 24, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a garmin gps nuvi 255w and I wanted to register it, but a massage keeps on poping up saying external power lost shuting in 29 seconds.What should I do?
Anonymous
Level 3:
  • Master 321 Answers
  • Posted on Dec 24, 2010
Anonymous
Master
Level 3:
Answers
321
Questions
0
Helped
110672
Points
1111
Try to charge your nuvi properly and full, or for at least 2hours before registering it. If the source of power connected to your nuvi is not strong enough, the nuvi might go off during an operation. Secure that the battery is well charged, then the source supplying the power is good enough to supply your nuvi with power before starting an operation.
Hope this helps.
Im not getting any signal on my garmin nuvi 255w
If your garmin nuvi 255w in not getting any signal try to reset the unit by holding the power off/on button for about 15 seconds, that way it will restart the unit and it will start to work properly, but if it does not still work, then you need to disconnect the gps device and take it out of the car to an area where the gps will directly face the sky. That way it will receive signal. Or you can connect an external antenna to it.
That should do the job.
tip
Nuvi 255W Webupdate
Garmin Nuvi 255W Webupdate
Models: Garmin Nuvi 200, 200W, 250, 250W, 260, 260W, 270
Models: Garmin Nuvi 205, 205W, 215, 215W, 255, 255W, 265, 265W, 275
Does your Garmin Nuvi 200 or 200W GPS get stuck or freeze at startup, or when loading maps?
Looking to reflash the firmware / system software for your Garmin GPS device?
Replacing the brains of your Garmin GPS is the surest way to resolve freezing, hanging, and erratic behavior. Keeping the system software and firmware in your Garmin GPS current and up-to-date is also the best way to keep it performing well.
Your GPS may not start properly at all, and display a 'System Software Missing" message. This tip will describe how to restore your Garmin Nuvi GPS system software using Garmin Webupdater.
  1. The first step is to download the WebUpdater software.
  2. Plug in your Nuvi GPS into your PC with the USB cord.
  3. Run the WebUpdater program to install it to your computer and update the system software of your GPS.
Your Garmin Nuvi should now be running as good as new.
I hope that helps.
____________________________
Download Nuvi 255W Manuals here.
Garmin Nuvi 255W Hard Reset Here.
Garmin Nuvi 255W Favorites Backup here.
tip
Download Nuvi 255W Manual Models: Garmin Nuvi 205, 205W, 215, 215W, 255, 255W,...
Have you lost your User's Manual or the Quickstart Guide for your Garmin Nuvi 255 or 255W GPS?
Would you like a digital copy for easy searching of terms and quick reference?
Both manuals are available in pdf format, just follow the photo links below:
I hope that helps.
Garmin 255W WebUpdater here.
I need help to register my nuvi 255w
  1. Connect your satnav to your computer using the mini USB cable.
  2. Go to www.garmin.com
  3. Select your country from th drop-down arrow
  4. Click on th myGarmin tab at the top of the page
  5. Click on "Register your garmin device" and follow the prompts
You'll be asked to create a username and password. Keep them safe as you'll need them if you want to update maps
Would like to register my Nuvi 255w Gps
If you need it regiserd call garmins 1800 number and tell them you want it registered and they will take all your info iv done it
I want to register my Garmin 255w GPS
To Register your Garmin Satnav
  • Connecty our satnav to your computer and go to www.garmin.com
  • Select your country
  • Click on "Register your garmin product"
  • Follow the prompts
Note you will be asked to create a username and password. Write them down and keep them safe as you'll need them again anytime you want to update your maps
3helpful
I can't register my garmin nuvi
I went back to Garmin and started again at the brginning and was successful in the registration,
Thanks
Cannot register Garmin Nuvi 250 purchased today
Can anyone help me in registering garmin nuvi 255W? Also, once I connected the USB, I keep getting "External Power Lost". Is this always the case as the USB is connected?
Oct 31, 2008 • GPS
Top Garmin GPS Experts
vince
Jesse Walters
Jesse Walters
Are you a Garmin GPS Expert? Answer questions, earn points and help others
