Question about Danco Faucet Stem
Shower is leaking when I turn the the hot or cold water off I replaced the hot and cold water knobs but it still leaks I didn't change the washers what is causing the problem
Posted by frencht79 on
Anonymous
    New Friend:
    Problem Solver:
  • 8 Answers
Replace the seats in faucet body -a special wrench is usually required
Posted on Dec 24, 2010
Have changed all washers and reseated taps in shower but shower head still leaks
hi mark.
this is all i could find on the internet,if this is no good to you go to the link at the bottom and see if it helps you out.
First, feel the water leaking from the tub spout or shower head. If it's warm, you know that the leak is coming from the hot-water valve. If the water has been dripping for a while and it is cold, the leak is probably coming from the cold-water valve. 1Start by removing the faucet handle.22 Nov 2016
How to Repair a Leaky Shower Faucet Valve - HomeTips
shower head leaks Google Search
Nov 18, 2017 | Home
I'm not sure what brands my faucet or handles are.
You can remove the center (Diverter valve) without turning water off, Will need deep well socket. Check the o rings and or washers and replace or take valve to Home depot to match with new. If you can't find one there go to local plumbing supply or ace. I turn hot then cold on and off real Quick while the valve is out just to clear anything that might be in lines. stand to the side or you will get wet! You might want to get new hot and cold valves while your at it just make sure to turn off water at meter before you remove them.
Jun 06, 2017 | Home
Water leak behind shower wall when i turn on hot and cold water
If it only happens when you turn the water to the shower on, it must be a problem with the piping after the valve. Take the shower arm out and wrap it with Teflon, it could be as simple as leaking threads. It could also be a leaking/poorly soldered copper fitting, or even a defect in the enclosure itself.
Feb 27, 2014 | Home
How to install a danco 10472 4z-24h/c hot & cold faucet stem
  • Shut off water supply
  • Open faucet
  • Remove knob
  • Unscrew old stem
  • Use flashlight to inspect seat for damage and corrosion. Dress or replace seat if necessary.
  • Install new stem
  • Reinstall knob
  • Turn on water supply and check for leaks
Feb 09, 2014 | Danco Faucet Stem
Push Pull Shower Valve also off in middle position
If you turn it to left or right (hot or cold) and get water out of the shower head,we'll elimate cloged shower head.If it just doesnt work in the middle ,probily a washer is stuck in your diverter,or to better understand>a part inside your shower knob assembly is clogging the water that goes up to your shower head. If you get water out of the shower head in the just cold possition or just hot position,then you will have to dissasemble the unit to repair. If you get no water in the cold or hot position could just be a clogged shower head.If you dont know how to disasemble a Shower diverter ,I wouldn't recommend taking it apart. Hope this helped!
Feb 09, 2012 | Moen Home
I have an american standard shower knobs for cold and hot with a center control that directs to shower. Tub faucet leaks. How do I fix this?
Pull the knob off...usually the screw is behind a cover in the center of the knob...
Behind the knob you will find a nut that is the packing nut ... this is what keeps the water from running out around the stem...turn that nut clockwise a quarter to a half turn or until snug...
this iwll fix your leak...
heatman101
Aug 14, 2010 | Plumbing
Have no Cold water coming out of shower/tub. Replaced the Moen cartridge and still, no cold water. When knob is turned right I get hot water when turned left I get a trickle of hot water.?????
Hello
Take the plastic knob off.Turn the brass stem with a pair of pliers until you get it in the proper position.
Off faces down
Cold faces left
Hot faces right
Once in the position screw pastic knob back on.
Mar 16, 2010 | Moen & One Handle Tub & Shower Faucet
Water leaks from my cold water and hot water shower handles (separate) whether the water is on or not. How can I fix this?
turn the water off! at the meter and go buy a faucet seat removal tool its L shaped with square heads on each end also buy a faucet valve socket to remove the faucet stems after you take the knobs and unscrew the trim housings once you unscrew the faucets stems there inside the hole deep is 2 brass seats that you need to remove and change put the new seats in and replace the washers on the stems and reassemble
Jan 20, 2010 | Home
Shower handle leak
turn off main water in home . turn on tap some where in home to release presser take shower handle off (screw under cap) unscrew the tap with a wrench unscrew on insides you pull out replace washer put all back togethere
Feb 11, 2009 | American Standard 3275.505.099 Colony Soft...
Danco Faucet Stem  Logo
252 people viewed this question
Top Danco Home Experts
Bill Johnson
mehan
Level 1 Expert
Tom Chichester
Are you a Danco Home Expert? Answer questions, earn points and help others
