My receiver model is Pioneer XV DV787. it was working perfectly for more then seven years, just there was SUB COM message blinking continuously otherwise everything was functional and perfect.Just to solve the blinking "SUB COM."massage, I applied the mentioned reset method.After that I am experiencing exactly the same problem.Nothing is working except power on/off and blinking same old message "SUB COM"
SOURCE: tv wont turn on
That same thing just happened to my t.v. The repair person will be here on 10/10/06. I will let you know what they say.
SOURCE: pioneer xv-dv8
ours did the same thing. Make sure that the switch on the back is set to 120 volt. That fixed ours
SOURCE: Viper 791 XV Automatic Start Not Working
Viper Working installed in my 2000 Honda Civic. It's the 791 XV model I nite diagram
SOURCE: Primare A30.2 power amp has
Check for the fuses inside the machine, replace only with same ratings! Make sure there's no shortcircuit at the speaker output terminals. Have it checked out by your local dealer if you are in doubt.
Pat.
