Question about Konica Minolta bizhub C450P Laser Printer
I have a Konica Minolta bizhub C450. Can the image unit be reset?
Posted by cbwat2003 on
just me
    New Friend:
  • 60 Answers
It may, but this mean that next time you put toner on the machine, you will expect less copy quality and printing for each toner bottle.
Posted on Feb 24, 2011
KONICA MINOLTA C450 DEVELOPER
Sir/Mam you do not need developer for the C450 it already comes inside the image unit the copier tells you to replace.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Sep 05, 2014 | Konica Minolta bizhub C450P Laser Printer
Konica minolta bizhub c450 error code c-2555
Yellow Imaging Unit Failure.
Take out IU-Y, shake it, check the toner layer, Re install it.
and see if improvement, else remove IU-Yellow
May 06, 2013 | Konica Minolta bizhub C450P Laser Printer
How to reset konica minolta bizhub c450
you have to replace the parts its need or Replace Chip on the image unit
Take the front plastic cover off the black IU and you will see the chip (a small pcb ) that you need to replace. Unplug the connector and remove the old board. Put the new pcb in and connect the connector.
Aug 05, 2012 | Konica Minolta bizhub 350 All-In-One Laser...
How I can reset counter imaging unit bizhub c450?
u cant reset those , u have to change the counter chips .These are available in market
Apr 19, 2012 | Konica Minolta Office Equipment & Supplies
How do I reset the Unit Life after replacing black imaging unit?
Just reset the chip. More details you can find here: http://www.chipreset.eu
Aug 11, 2009 | Konica Minolta bizhub C450P Laser Printer
Imaging Unit Problem with bizhub C450
On the end of the image unit you will find a white bit of plastic with a small screw in the middle, make sure this screw is tight and then reinstall the units(give the units a bit of a shake too)
Mar 02, 2009 | Konica Minolta bizhub C450P Laser Printer
Bizhub C450
sounds like the wrong image unit. Oce and ollivetti have the same machine and take the same image unit but with a different chip. Make sure it is a genuine konica minolta image unit. If need be try putting the chip from the old unit on the new one and see if lays down the colour
Jul 10, 2008 | Konica Minolta bizhub C450P Laser Printer
Konica Minolta bizhub C450P Laser Printer Logo
463 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
carpediemweb
Level 1 Expert
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
