Question about Sony FD Trinitron WEGA KV-32HS420 32" TV
Sony FD Trinitron WEGA KV-32HS420 32" TV.....Turns
Anonymous
    New Friend:
  • 66 Answers
Sounds like a diode may have burnt up or if your really lucky it might just be the fuse.!!! You might want to get a secound opinion .But if you know what to look for , which is any component on the motherboard that appears as if had caught fire sader it out amd replace with exact same component which can be ubtained at radio shack.GOOD LUCK TOO YOU!!!!!!!!!
Posted on Dec 24, 2010
Sony FD Trinitron WEGA KV-34HS420 34" TV Stand by
I have the indentical tv and problem. Cost to repair was about 250.
Aug 19, 2011 | Sony FD Trinitron WEGA KV-34HS420 34" TV
I have a sony wega trinitron, when the tv is turned on, (no visual, or sound) the red stand by light blinks 7 times, and you hear the tv click off? Please help
Seven blinks - High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
Jun 06, 2011 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Won't turn on.stand-by light flashes.timers are
my Sony trinitron kv-g21s2 TV not working . conned to the power blink in TV power indicator led
May 29, 2011 | Sony FD Trinitron WEGA KV-13FS100 13" TV
Stand by light blinking 7 times. occassionally turns on when pressing reset and power button.
  • Seven blinks - High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
There is a High Voltage fault or power supply fault.
Hope that helps.
Dec 09, 2010 | Sony FD Trinitron WEGA KV-30XBR910 30" TV
Sony Trinitron TV
read the answer on this page really helpfull
http://en.allexperts.com/q/TV-VCR-Stereo-1749/Sony-Trinitron-KV-32V42.htm
Apr 01, 2010 | Sony FD Trinitron WEGA KV-27FV17 27" TV
Sony wega kv-32hs510
place blow dryer on heat setting to rear of tv and try to turn on set after 5 mins...humidity sensor in board
Sep 06, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony FD Trinitron WEGA Standby Light Blinks, TV Does Not Turn On
Sony FD Trinition Wega KV-32HS510 Try to turn tv on -it starts then shuts off -stand by lights keeps flashing. Memory stick light flashes then goes off.
Nov 29, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony FD Trinitron WEGA KV-36XBR800 36" TV
I get a black screen after power on...then a bright white light in the middle of the screen.Then the red light flashing and turns it self off.
Oct 27, 2007 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Sony FD Trinitron WEGA KV-32HS420 32" TV Logo
331 people viewed this question
Top Sony Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
