Question about Whirlpool Freezers
My whirlpool american fridge freezer keeps making a beeping noise. The Triangle sign located between the two temperature settings keeps lighting up as well. The infrared light inside the freezer under the ice maker is turned off. The fridge freezer is not working all my food is defrosted.
Posted by kim_cozzy on
5 Related Answers
Master_Tech
Gary Davd
  • 770 Answers
SOURCE: Ice Maker
the LED's are optics they sense the level of the ice in the bucket on the door under the icemaker is 2 1/4" screws you can remove the IM and the white cover put a small jumper in the pins T and H this will cycle the IM the door and optices will need to be closed (or best to tape them so you can leave the door open the IM should cycle if nt check the power at the N and L pins see if you have 120vs then we can go from there
Posted on Apr 08, 2008
Anonymous
  • 674 Answers
SOURCE: american fridge freezer siemens KA58NA50GB. Freezer not freezing
If you are not capable to do that much better to call service Engineer to avoid big damage of your Freezer.
Posted on Apr 04, 2010
Anonymous
  • 523 Answers
SOURCE: have a whirlpool american fridge freezer - we
try pluging it in else where if it still does it theres a dead short mabey in the compressor
Posted on May 05, 2010
miket756
Michael Thorpe
  • 2702 Answers
SOURCE: Hi, i have a whirlpool american style fridge that beeps etc.
its the compresor packed up,,,if this compresor is not pumping freezer gas around the pipe work the freezer wont work sorry but a new compresor is not a cheep thing to have fitted as it will need a re-gas as well
Posted on Jun 29, 2010
heatman101
D. Floyd Kolb
  • 43501 Answers
SOURCE: Bosch FD8709 Fridge Freezer (American Style)
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Aug 05, 2011
Testimonial: "Thank you for your generous support. I found a lot of dust under the unit, turned it off, cleaned-up, and it appears to be working at the moment."
Whirlpool fridge freezer
Totally a normal action.. When the compressor switches off once the temperature is reached, or possibly after a defrost cycle, if the gas hasn't quite equalised, it will click once or twice then start up.If the compressor has a starting capacitor and it does the clicking, then one needs to check the capacitor.
Sep 22, 2013 | Freezers
Jun 29, 2010 | Freezers
American fridge freezer siemens KA58NA50GB. Freezer not freezing
Apr 03, 2010 | Freezers
My american fridge freezers alarm has just gone off and the temperature is reading -- and flashing
is it a side by side if so it is more likely your rear brd that has failed and needs replacing. This brd controls the appliance.It is located in the rear behind the panel at the bottom. Looking from behind it is in the bottom right hand corner
Mar 26, 2010 | Whirlpool Freezers
It keeps tripping its a whirlpool american fridge freezer
does it trip as soon as you turn it on. If so then it is ur defrost element this is situated behind the panel in the freezer at the back.
Hope this helps
Mar 15, 2010 | Whirlpool Freezers
Freezer not working on ariston fridge freezer 2 orange lights on top of fridge keep beeping every two hours causing fridge not to work is there a reset button
freezer not working on ariston... Solve freezer not working on ariston fridge freezer 2 orange lights on top of fridge keep beeping every... (More) freezer not working on ariston fridge freezer 2 orange lights on top of fridge keep beeping every two hours causing fridge not to work is there a reset button
Sep 13, 2009 | Freezers
New whirlpool refrig. freezer ok at 0 but refrig
The freezer get the first crack at cooling and combination units have a fan and adjustable vents to steal some of the cooling capacity for the refrigerator. The vent are normally located in the back of the refrigerator compartment and with these, you can balance the cooling capacity between freezer and fridge. I recommend you swap your thermometer back and forth until you get the balance you want; typically the freezer should be at 5 degrees F or below and the fridge at 35-40 degrees F. Adjusting the control for temperature and having the vents set to supply the cold air you want in each compartment should give you the range you want in each.
Sep 09, 2009 | Whirlpool Freezers
After power cut the temperature of the fridge and the freezer termperature are just flashing and making a beeping noise
It means the compartment temperatures are increased then allowed limit.Generally in some appliances the maximum temperature is indicated at the display with an alarm after the electric cutoff.If the temp is high in the compartments
Jun 29, 2009 | Whirlpool Freezers
WHIRLPOOL UNDER WORKTOP FREEZER APPROX 11 YEARS OLD BEEPING
the temperature control is bad. when you push the fast freeze it bypasses the thermostat for 12-24 hours depending on which model you have. I am not able to find any parts information with the model number provided but you should be able to find a temperature control at any local appliance parts house or online thru any reputable supplier. Thnaks Peyton
Feb 24, 2009 | Whirlpool Freezers
Whirlpool 20RB D4 Fridge Freezer clicking
Hi the reason for your noise coming from the fridge freezer is the plastic that is used in the design of your product is of a low quailty which reacts to the temp change and then as they get cold again they start to crack inside the frigde! Nothing to worrry about........
Hope this helps.....
Dec 23, 2008 | Freezers
Freezers Logo
295 people viewed this question
Top Whirlpool Freezers Experts
Muntejaya Ginting
Muntejaya Ginting
Dennis Boxerman
Jim
Are you a Whirlpool Freezer Expert? Answer questions, earn points and help others
