Question about Thermador Ovens
Thermador oven will not self clean.The blower fan does not turn on, and the word HEAT never appears when LOCK stops blinking. In other words, after following steps 1,2 and 3 fan and heat never happens.
  • Thermador Master
  • 43,501 Answers
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!!
Posted on Dec 23, 2010
I have double wall unit Thermador oven. After self cleaning, the door can not open. Or may be I hit the panel lock , so the door is lock. How to unlock?
Hello April,
If any OVEN FUNTION is being used...
The controls cannot be LOCKED off...
So no... REQUIRES PUSHING 2 buttons & holding
for four (4) seconds... (not likely to be accidental)
The steps to Lock & Unlock are the same...
(see reference page (click here)
Thermador SCD302 Care And Use Manual Child Lockout
Touch and hold the COOK TIME pad and
the STOP TIME pad simultaneously for 4
seconds.
Likewise SELF CLEANING is described in great detail.
(double click this URL)...
Thermador SCD302 Care And Use Manual Page 29
ELSE...
Please contact THEM if you have questions or comments.
Phone: 1-800-735-4328 or reach THEM through their
website at www.thermador.com
Hope this helps
Carnac the Magnificent
Dec 20, 2017 | Thermador Ovens
Our Thermador oven starts to beep when you shut it off and the way we are getting it to stop beeping is to set up a fan in front of the open oven to get it to cool. This stops the beeping after 10 m
Check if the internal ventilation fan is running. It is intended to cool down the oven exterior. Some units made 2004-2007 can overheat during self-cleaning.
Oct 14, 2014 | Thermador C301U Electric Single Oven
F82 error
door switch not sensing properly or a bad power relay board.
Oct 01, 2012 | Thermador Ovens
Heating element on upper oven of a wall Thermador Oven
The control switch may be bad on it. If there are 2 elements on the top, they both are not bad at the same time.Check to see if the wires have not burned off the control switch first. Check to see if your breakers are O.K. Turn them both(maybe 3) off and then reset.
Jan 30, 2009 | Thermador Ovens
Wont lock in self clean
Whirlpool Gold range: start the self cleaning but after message: cln door comes message, E1-F5- . door does not lock and cleaning can not start.
Oct 10, 2008 | Thermador C302U Electric Double Oven
Self cleaning lock handle does not unlock
Unplug power, wait one hower and plug cord back.
That should reset the oven, if it does not, the oven timer control is clearly defective and should be replaced , you find parts here.
Oct 08, 2008 | Thermador Ovens
Thermador double oven / Bake wont work /FC code flashed once
I found I have this exact problem. Same bake preheat issue: I can bake if I set broil first. However, the oven doesn't work if I press bake first. The control board has already been replaced a couple times over the years. Is this another replacement??
Aug 30, 2008 | Thermador SC272T Electric Double Oven
Thermador Oven won't heat after running self-cleaning cycle
SOunds like you need to reset the oven high limit switch. It should be located behind the grille obave the oven opening and below the control panel. There should be about 4-6 screws you need to take out to remove the grille to gain access. Turn the power of to the oven at the circuit breaker, then rech in with a screwdriver and push down on the little red button in the center of the hig limit until it clicks. the high limit should be about as big around as a quarter and have a wire going into one side and out the other. If this keeps tripping, you may have a bad cooling fan. When you run a self clean it should also run a fan to cool the components. You should be able to feel a breeze coming out of the bottom of the oven when the cooling fan (not the convection fan ) is running. If this fan doesnt run, it will trip that switch. Hope this helps!
Dec 08, 2006 | Thermador C301U Electric Single Oven
Ovens Logo
614 people viewed this question
Top Thermador Ovens Experts
Marvin
Marvin
Ismael Rodriguez...
Charles Tidwell
Are you a Thermador Oven Expert? Answer questions, earn points and help others
