Question about Keurig B60 Coffee Maker
Sorry to read about your issue.
The brewer should be de-scaled at least every 3-6 months. Scale is harmless, but if left unattended, it can hinder optimal brewer performance. De-scaling your brewer regularly helps maintain the heating element, removable water reservoir and other parts of the brewer that come in contact with water. Better water quality and water heating means a better cup of coffee, tea, hot cocoa or iced beverage. We recommend de-scaling your brewer at least every 6 months (every 3 months if your water has a high mineral content). The de-scaling process involves using 48 ounces of undiluted white vinegar.
Take 48 oz of white vinegar. place in tank. pretend you are making coffee (Do No Use K Cup). let the water fill you mug. then empty that mug. Do it again until tank is empty. then let sit for 4 hours.
Then fill with fresh water to the top. let that tank of water run thru. towards the end taste the water.
If you taste vinegar..use more clean water, until the taste is ok.
I tried to help you. Please help me and Vote/Rate this response. Thanks and good luck
bcvb
cbcb
cvbcbc
Posted on Dec 23, 2010
SOURCE: My Bunn coffee filter overflows
If this is a pour-over coffeemaker, you can't do anything about the flow. It's just gravity pushing the water out of the reservoir. But you can try using a coarser grind of coffee. If the grind is too fine (if you grind whole beans for too long in a blade grinder, for instance, or if you're using espresso grind coffee), the water can't flow through quickly enough and it backs up and overflows. Make sure your coffee is ground for a drip coffeemaker.
Posted on Aug 02, 2011
