Question about LaCie d2 Extreme 250GB External with Triple Interface USB 2.0/Firewire 400/800 - 300790U ... Hard Drive
An external storage-device has four major components:
* the USB cable
* the power-adapter
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure.
One of these components has failed.
Try a different USB cable.
Try connecting to a different USB port on your computer.
Try connecting to a USB port on a different computer.
Take a "multi-meter" and measure both the voltage and amperage output from the AC adapter, and compare with the specifications on the label on the adapter.
Open the enclosure, and remove the disk-drive, and then connect it as a "slave" disk-drive in a desktop computer, to see if it works at all.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Get the part-number and serial-number from the label on your disk-drive, and access the manufacturer's web-site, and use "check warranty status", to see if they will replace the device, at minimal cost to you.
There exist commercial "data recovery" services that can try to repair your device, just long-enough to rescue and copy your files. For example, see: https://services.seagate.com/index.aspx?lng=en-US for a "no data - no charge" guarantee.
Posted on Dec 23, 2010
Aug 05, 2011 | LaCie 2TB d2 Quadra Hard Disk v21
Jan 13, 2011 | LaCie d2 Extreme (300790U) 250 GB Hard...
Jan 10, 2011 | LaCie (300740) 160 GB Hard Drive
Jul 21, 2010 | LaCie d2 Extreme (300793U) 500 GB Hard...
Nov 24, 2009 | LaCie d2 (300769) 200 GB Hard Drive
Sep 22, 2008 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
Jan 07, 2008 | LaCie D2 Extreme 300 GB Hard Drive
Dec 20, 2007 | LaCie d2 Extreme 250GB External with...
Sep 24, 2007 | LaCie d2 (300769) 200 GB Hard Drive
115 people viewed this question
