One thing at a time.
The real time clock is kept on time by a CMOS battery and if the battery goes flat, the time will be lost as will the CMOS data that tells the notebook that there is a hard drive installed.
Replace the CMOS battery first, set the time and date in the BIOS then let the BIOS detect the hard drive.
When the BIOS bit is happy, place a system disk in the DVD Drive and load a fresh OS.
Hope that helps, and have a nice Xmas.
a. Click Start, type services.msc and hit ENTER.
b. Locate Windows Time.
c. Right-click and select Restart. make sure there are no disks in cd floppy usb drives Test all leads that attach to your hard drive including electrical extensions IDE,SATA the leads from your ((MOTHERBOARD TO YOUR HARD DRIVE)) make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty if its a flat ribbon 40 pin IDE it will be the fist to fail
there can be a number of things that can halt the boot process
bios settings not right
bad or faulty leads
faulty bootmanger
make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs data and power to travel through every working device and to continue its cycle and to have an end so any faulty leads will end up with a computer error
also make sure you have set it boot from you hard drive in BIOS
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS the using arrow key scroll down to advanced bios features press enter make sure your first boot device is set to your hard drive press escape then press f10 to save to cmos to restart
IDE-0 means Pri master ?
IDE-1 means Pri slave ?
IDE-2 means Sec master ?
IDE-3 means Sec slave ?
hope it helps
