Lenovo IdeaPad S10e Notebook Logo
Posted on Dec 23, 2010
How can i create a proxy??? - Lenovo IdeaPad S10e Notebook
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 12 Answers
  • Posted on Dec 23, 2010
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
12
Questions
0
Helped
2373
Points
20
What makes you believe you need one and for what? usally is a different issue
Straighttalk settings for blu phone
try this one
had the problem going through forums trying to find the settings that work for my phone but to no success but I finally figured it out and I'm posting it on here just in case some one else has my same problem.
I had to create two separate APN's one for internet and one for MMS. Settings are as follows:
Internet:
Name: Straight Talk Internet
APN: att.mvno
Proxy: proxy.mvno.tracfone.com
Port: 80
User Name: Not Set
Password: Not Set
Server: Not Set
MMSC: Not Set
MMS Proxy: Not Set
MMS Port: Not Set
MCC: 310
MNC: 410
Authentication Type: PAP or CHAP
APN Type: Internet
APN Protocol: IPv4
Bearer: Unspecified
MMS
Name: Straight Talk MMS
APN: att.mvno
Proxy: Not Set
Port: Not Set
User Name: Not Set
Password: Not Set
Server: Not Set
MMSC: http://mmsc.cingular.com
MMS Proxy: 66.209.11.33
MMS Port: 80
MCC: 310
MNC: 410
APN Type: Internet+MMS
APN Protocol: IPv4
Bearer: Unspecified
Do not forget to create two separate APN's!!!!!
goodluck
How do I set up my own elite proxy server?
Setup your own Proxy Server in 5 Minutes for Free var google_adnum = 0; function google_ad_request_done(google_ads) { var u = ''; var i; if (google_ads.length == 0) { return; } else { for (i = 0; i ' + google_ads[i].line1 + ' ' + google_ads[i].visible_url + '
' + google_ads[i].line2 + ' ' + google_ads[i].line3 + ' '; if (i '; } u = 'Ads by Google ' + u + ''; } google_adnum = google_adnum + google_ads.length; document.write(u); return; } google_ad_client = 'pub-3152670624293746';google_ad_output = 'js';google_ad_type = 'text';google_feedback = 'on';google_language = 'en';google_encoding = 'utf8'; google_max_num_ads = '2'; google_ad_channel='9126605320'; google_skip = google_adnum; google_protectAndRun("ads_core.google_render_ad", google_handleError, google_render_ad); Ads by Google Google Analytics www.google.com/analytics
Understand how people find, explore & convert on your site - Now free. google_proxy.jpg
A simple Google search and you'll find dozens of really good PHP scripts on the Internet to help you create proxy servers in minutes for free. The only limitation with PHP based proxies is that you require a web server to host the proxy scripts and second, you also need a domain name to act as an address for your proxy site.
If you don't own a domain or server space, you can still create a personal proxy server for free and that too without requiring any technical knowledge.
Create a Free Proxy Server with Google App Engine Here's one such proxy site that you can build for your friends in China or even for your personal use (say for accessing blocked sites from office). This is created using Google App Engine and, contrary to what you assume, the process is quite simple.
Step 1: Go to appengine.google.com and sign-in using your Google Account.
Step 2: Click the "Create an Application" button. Since this is your first time, Google will send a verification code via SMS to your mobile phone number. Type the code and you're all set to create apps with Google App Engine.
Step 3: Choose a sub-domain* that will host your proxy server. Make sure the domain is available, agree to the Google Terms and click save. The sub-domain is also your App ID that will uniquely identify your proxy application.
For this example, we'll use labnol-proxy-server as the App ID though you are free to choose any other unique name.
Step 4: OK, now that we have reserved the ID, it's time to create and upload the proxy server application to Google App Engine. Go to python.org, download the 2.6.4 MSI Installer and install Python.
1_create_app_engine_account_thumb.png 2_verify_mobile_thumb.png 3_authenticate_thumb.png 4_create_application_thumb.png
install_python_thumb1.png install_app_engine_sdk_thumb1.png sdk_preferences_thumb.png
2helpful
How do i set my internet,wap,mms,gprs and phone settings manually on my GB230
Hi, we will go step by step taking the example of Airtel Service provider..
Step 1: Provide an Acess Point
Go to 'Main Menu' then 'Settings' and then go to 'Access Point'
If you have activated Mobile Office then:
fill the follwing details.
Connection Title: Mobile Office (or anything you want to write)
Bearer: GPRS
Authentication: (Leave it as it is)
APN: airtelgprs.com
If you have activated Airtel Live then:
Connection Title: Airtel Live (or anything you want to write)
Bearer: GPRS
APN: airtelfun.com
If you have activated Airtel MMS then:
Connection Title: Airtel MMS (or anything you want to write)
Bearer: GPRS
APN: airtelmms.com
Step 2: Create an Internet Profile:
Go to 'Main Menu' then 'Settings' and then go to 'Internet Profile'
User Proxy: OFF
Access Point: select the one that you have created for mobile office in access point setting.
User Proxy: ON
Proxy Server Adress: 100.1.200.99
Proxy Server Port: 8080
Access Point: select the one that you have created for Airtel Live in access point setting.
User Proxy: ON
Proxy Server Adress: 100.1.201.172
Proxy Server Port: 9201
Access Point: select the one that you have created for Airtel mms in access point setting.
Step 3: Activating a Profile:
Go to 'Main Menu' then 'Web' then 'Settings' and then go to 'Profile'
then select the profile that you want to activate.. if then it dosent work then you can try restarting the handset...
NOTE: For working on Mobile Office, first you need to get it activated from airtel.. just call the customer care, talk to the representative, and ask them to activate the MO service after checking the tarrif.. and the enjoy surfing and mms_ing
Please give a proxy ip
Why do you need a proxy IP? Your router should supply it automatically unless you are in an office where the network adminsitrator has created one and has to give it to you. No one will know what it is unless someone creates it and assigns it to you.
You can however have the pc selected to AUTOMATICALY detect ip proxy
In the Network neighborhood section of you Os
2answers
I need a proxy that cant be blocked solve this
http://www.torproject.org/torbrowser/dist/tor-browser-1.3.2_en-US.exe
Gprs, mms and inet seetings for se c510
GPRS Settings:
1. Go to Menu>Choose Settings. Press Left Navigation Key to go to Connectivity. Scroll Down and click Internet Settings
2. Choose Connect Using: and Add Data accounts. Enter the following parameters
Account type: PS data
APN: www.globe.com.ph
3. Save Account
4. Choose Options Menu by clicking the left soft key.
5. Choose Edit. Leave all the settings as default except Proxy Settings.
6. Go to Proxy Settings and Edit.
Proxy: On
Same for all servers: Off
Proxy servers: Multiple
7. Click Edit on Proxy servers. Choose HTTP.
Username: Blank
Password: Blank
Proxy address: 203.177.42.214
Port: 8080
8. Press Back four times
9. Press Select to choose myGlobe CONNECT as default account.
10. Press Save.
11. Go to Main Menu> Internet>Options>Advance. Press Left Navigation Key to go to Connectivity.
Connect using: MyGlobe CONNECT
Default Homepage
Address: http://www.globe.com.ph/globe.asp
12. Press Save
MMS:
1. Go to Menu>Messaging>Settings>Picture message
2. Go to MMS profile
3. Create New Profile.
MMS profile name: MyGlobe MMS
Message server: http://192.40.100.22:10021/mmsc
4. Choose Connect using: and Edit.
5. Choose Options Menu by clicking the left soft key.
6. Create New and enter the following parameters
APN: mms.globe.com.ph
7. Save Account
8. Choose Options Menu by clicking the left soft key.
9. Select Edit. Go to Proxy Settings and Edit.
Proxy: On
10. Click Edit on Proxy servers. Choose HTTP.
Username: Blank
Password: Blank
Port: 8080
11. Press back four times
Press Save. Select MyGlobe MMS as new MMS profile
1helpful
2answers
Nokia phone wont connect to the GPRS
Creating Data Accounts
Steps:
1. Open Services Menu.
2. Open Data Account.
3. Open GPRS.
4. Create/Edit Data Account and enter the following values:
For Globe MMS Data Account:
Account Name: GlobeMMS
User Name: leave it blank
Password: leave it blank
Auth. Type: Normal
For Globe GPRS Data Account:
Account Name: GlobeGPRS
APN: http://www.globe.com.ph
Auth. Type: Normal
For Smart MMS Data Account:
Account Name: SmartMMS
APN: mms
Auth. Type: Normal
For Smart GPRS Data Account:
Account Name: SmartGPRS
APN: smart1
Auth. Type: Normal
5. Save the Data Account.
Configuring WAP/GPRS/Internet Services Using the Data Accounts Created
2. Open WAP.
3. Open Settings.
4. Open Edit Profile.
5. Create/Edit a Profile and enter the following values:
For Globe GPRS Profile:
Rename Profile: myGlobe GPRS
Homepage: http://www.globe.com.ph/globe.asp
Data Account: GlobeGPRS (this data account is the one you have created)
Connection Type: HTTP
Proxy Address: 203.177.042.214
Proxy Port: 8080
Username: leave it blank
For Smart GPRS Profile:
Rename Profile: SmartGPRS
Homepage: http://wap.smart.com.ph
Data Account: SmartGPRS (this data account is the one you have created)
Proxy Address: 010.102.061.046
Proxy Port: 8080
6. Save the Profile.
7. Activate the Profile.
8. WAP/GPRS/Internet services now ready to use. In case you encounter errors, double check the Data Account and Profile created. In some cases you need to restart the phone.
Configuring MMS Using the Data Accounts Created
1. Open Messages.
2. Open MMS.
3. Open Message Settings.
4. Open Server Profile.
For Globe MMS Profile:
Rename Profile: GlobeMMS
Homepage: http://192.40.100.22:10021/mmsc
Data Account: GlobeMMS (this data account is the one you have created)
Proxy Address: 192.040.100.020
Proxy Port: 8080
For Smart MMS Profile:
Rename Profile: SmartMMS
Homepage: http://10.102.61.238:8002
Data Account: SmartMMS (this data account is the one you have created)
Proxy Port: 8080
8. MMS services now ready to use. In case you encounter errors, double check the Data Account and Profile created. In some cases you need to restart the phone.
2answers
How, where can i get the i.p adress of my china phone n5310,
hi dave, you can try visitiing smart centers, they can surely help you with that.
Top Lenovo Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
