Question about Toshiba 42H82 42" Rear Projection HDTV-Ready Television
My 42H82 picture works but fuzzy...Letters in menu are clear though..need help
Posted by jdbann82 on
Electro Med Services
  • Toshiba Master
  • 6,694 Answers
ur tvs crt sockets have some problem. change the three crt sockets at the same time . also check for screen voltages of crt's. increase it slightly. there will be three independent screen voltage adjustments for each gun.
ok
Posted on Dec 23, 2010
Anyone have problems with Panasonic TC-P60ST30 with white fuzzy picture mal-function?
Try going into set up menu and look for a screen degauzing function or try setting the screen temp. to warmer or cooler.
Aug 11, 2017 | Panasonic Viera Plasma TV TC-P60ST30
It has shrunk to about 6 inches all the way around the screen so the total picture sizr is 36 inches instead of the 42 inches otherwise clear picture little fuzzy when turning on but becomes a clear
Don't know what wires your using to connect to tv. It does matter, sometimes the connections go bad, either at the tv or cable box. Have you tryed to stretch picture in settings?
Feb 10, 2012 | Toshiba 42H82 42" Rear Projection...
Eiki projector problem
Just guessing here, are you feeding it the right resolution out of the source for the native resolution of the projector? Typically fuzzy fonts are caused by mismatch of resolution between a computer and it's display's native resolution. A projector can suffer the same issue.
Without having a full picture of what your doing, like model numbers, hard for me to help.
Nov 02, 2017 | Eiki LC-SM4 Multimedia Projector
Toshiba 42H82, no sound after fixing hyperboard.
Search for the audio amplifier - it's a chip with a radiator on it - the jack for the speakers should be close by.
Jan 09, 2010 | Toshiba 42H82 42" Rear Projection...
Toshiba 42h82 - "broken" picture
the "scan converter module" is located directly behind the board where your inputs are in the back of the set. That should repair the problem.
Jan 08, 2009 | Toshiba 42H82 42" Rear Projection...
My pictures turn out fuzzy all the time and i can't figure out how to turn on my flash. Please Help! Casio Exilim EX-Z70
Flash should turn on by pressing the "Set" button and then the down arrow until you get to the flash menu. Choose the setting that looks like a lightning bolt.
If that doesn't work press the "Menu" button and then press the "right arrow" until you are on the far right tab. Press the "up arrow" until you come to "Reset." Press the "Right arrow." The camera will ask you if you want to reset it. Tell it "Yes." This will take it back to factory settings and clear any mode that turns the flash off.
Are the pictures fuzzy because the flash isn't working? Are outdoor pictures in daylight fuzzy or OK? If they are fuzzy all the time you may have a lens problem. If they are only fuzzy when the flash is needed, fixing your flash should cure the problem.
Dec 18, 2008 | Cameras
The picture on my tv is warped
Hello jbvail86,
This problem you are having is a convergence problem. The convergence amplifiers are malfunctioning. Both Amplifiers need to be replaced. You will need a schematic, and a multimeter to check the voltages on the pins of the convergence amp ICs. Once you find that the ICs are bad you will need to de-solder them and the biasing resistors and replace the ICs and resistors. The schematic will help you find the proper resistor values.
I hope this helps
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Dec 03, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Fuzzy picture on Quickcam chat by Logitech
I can tell you how to fix it :D the white part where the lens is turn it ontil clear my dad did it for me its soooo clear! This is when its dark...e6c1bca.jpg
Mar 22, 2008 | Logitech Quickcam Chat Webcam
Fuzzy picture and in a different language
click on "menu".
then move to the "hand" while clicking on lightview
then clivk select/auto
it should automatically select the third from above
then move to the top while clicking on lightview
and now change the language with the "sun" buttons
Dec 17, 2007 | LG Flatron L1715S 17" LCD Monitor
Toshiba 42H82 42" Rear Projection HDTV-Ready Television Logo
76 people viewed this question
Top Toshiba Televison & Video Experts
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
