Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
SOURCE: 26690 Digital Camera, software won't load because
Hello!
According to this, your camera should be automatically recognized by Windows 7 - without the need of installing any special software. One connected it shoud get automatically configured, and should appear as an icon in Computer.
Note that the info on this link refer to the 26480 model, but as your model is ever newer, it's obvious the that info applies to it as well!
Hope this information helps you...
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Good luck & best regards,
Pelu
