Question about AEG 23 in. 6410KF-N Electric Cooktop
We got an E3 error message on induction cooktop(induction hob), AEG 88101 K-MN, which followed a popping sound. What could it be? We checked the braker and fusers.
Posted by annelonghurs on
  • Terry Procyshyn Aug 30, 2012
    I was boiling water on the right back burner as well as the front left burner on the power setting. I heard a pop and then got the message E3. It tripped the breaker downstairs. We left it off for a while and then put it back on and checked the panel on cooktop. The message stayed the same. First it shows E3 then all of the elements show E. Do you know what this means? How to fix the problem?
Barrett Palumbo
  • 1,772 Answers
Sorry to read about your problem, I hope this helps you out.
stop using and call a service company, before further damage occurs.
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Posted on Dec 23, 2010
I have an AEG induction hob which is 10m old. There has appeared a scorch mark in it that looks like it's from a pan. There is no burn or residue to clean off but it looks like the glass is damaged. Has...
not sure as to what you can do , if it did get too hot, maybe wrong pan, but could also be wrong temp in unit, only way to find out is to try and use warrenty
Jan 22, 2015 | AEG Cooktops
Neff induction hob error message flashing rear left r rear front E rear and front right 2
sir pls send me the answer when we put a pot on induction.after 30 minutes igbt get short
Dec 21, 2013 | Cooktops
Recently i have purchased Prestige induction stove, can you describe what does E3 mean?
e 3 is error because of high voltage may be more than 30 kW at your house......it will not work with it u have to buy a voltage regulator for it........
Jul 16, 2011 | AEG 23 in. 6410KF-N Electric Cooktop
Small pans do not work.
are you sure the small pan is made of conductive metal , ( used the magnet test ?)
Dec 13, 2008 | AEG 23 in. 67600KF-N Electric Cooktop
Miele KM5753 Induction Cooktop - Error 30
I have a KM5753 with FE31 and it remains after a breaker 1 minute re-set as per instruction booklet - anyone seen that one?
Mar 01, 2008 | Cooktops
AEG 23 in. 6410KF-N Electric Cooktop Logo
3,676 people viewed this question
Top AEG Cooktops Experts
Marvin
Marvin
Paul Carew
Are you an AEG Cooktop Expert? Answer questions, earn points and help others
