Question about LG DU-42PX12XC 42 in. Plasma HDTV
I have a red verticle line on my tv - LG DU-42PX12XC 42 in. Plasma HDTV
Posted by lori2524 on
John Dube
    Novelist:
  • 131 Answers
Hello; I am John at J D Electronics in Poland, Maine. I have an LG TV that was donated to me. It is a plasma model DU-42PX12X same as many other LG models. It had 1 inch wide red and green vertical bar on the right and a blue and yellow on the left. These bars appeared intermittently. pressing on the control board would make the bars go away. I have read many blogs on this problem and they all say to replace the control board located under that huge A / V input board ( held in by 4 screws on the large aluminum frame). The original part is # 6871QCH038A The replacement ends with a C instead of an A Aprox 90 to 135 dollars. This board is used on many different LG and Zenith models and is a HIGH failure rate part. I like to know WHY parts/boards fail and I found out why this board fails. There is a large square IC in middle of the board aprx 1 1/8 inch square. This type of IC is called BGA or Ball Grid Array. The solder connections cannot be seen , since they are under the IC . This IC was not properly soldered at the factory and that is why hundreds of these sets failed. I used my hot air soldering station on it's highest setting to heat up this IC . The IC must be directly heated from the top and some heat on the bottom of the PC Board. Liquid flux should applied to the 4 side edges of the IC prior to heating. The bars are now gone! To get to this board, remove all perimeter screws and all middle screws of the back cover. The A V board will hinge back to expose the control board if you unplug the cables to the side inputs and the one to the button board. The set will still run face down on a table with something to prop up the bottom screen so you can watch the bars. If the set was run for a long time with the bars, there will be some darkening where the bars have " burned" the screen. This is perminent, but usually acceptable. John
Posting advertisements, profanity, or personal attacks is prohibited. Click here to review our Terms of Use.
Comment:
Posted on Dec 23, 2010
2 Related Answers
Anonymous
  • 187 Answers
SOURCE: PERMANENT RED VERTICLE LINE DOWN THE SCREEN
Replace the timer control board
Posted on May 27, 2009
Azrael SRL
  • 11800 Answers
SOURCE: A thin red verticle line has apeared on screen, TV
Take it back, it's a fault in the LCD panel that cannot be fixed.
Posted on Mar 28, 2010
Testimonial: "Quick and helpful response thanks"
A thin red verticle line has apeared on screen, TV is a week old, can you advise
Mar 28, 2010 | Toshiba REGZA 47HL167 TV
Convergence issue; red 3D effect. In grid convergence mode blue will converge w/green fixed lines and red horizontal will but the verticle red will not adjust far enough left to converge. has ajustment...
Convergence is dead.Must know how to solders?Must replaced ICS and all of it resistors.Tries Tv repair World.com,Tvrepairkits.com for a convergence kit.The shop will cost u $300 for parts and labors.
Jan 24, 2010 | Hitachi 43FDX01B TV
Static verticle lines on screen
wiis dont do that but many tvs do im sure its the tv not the wii so it wont matter
May 21, 2009 | Nintendo Wii Console
Verticle black lines on mitsubishi dlp tv screen
Press the Menu Key on your remote. If your menu shows clearly on the screen, then there is a problem with your source.
Mar 02, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Panasonic color tv model ct-13r38sg 13"
verticle amplifier is not working on your tv
take it to a shop if you dont know.
verticle IC BE CHECKED.
AND ELETROLITIC CAPACITOR feeding verticle scan coil.
Jun 01, 2008 | Sony KV-27S65 27" TV
Polaroid 42" lcd has a distinctive verticle red line
you need to return the set where you purchased it, my humble opinion is replace it with a name brand that you know makes tv`s
for a living, ie; sony , hitachi, etc. when those "off" brands break there are many that have no access to service manuals or parts in this country, yours is one of them.
Nov 27, 2007 | Polaroid FLM-2011 Television
Red Line across Screen
sounds like you have a vertical sweep problem. Where the fault lies cpuld be the vertical output IC the verticle b+ feed, could be the capacitors in the vertical circuit?? Your gonna need to troubleshoot thr vrtical circuit if your not a tech thin my advise is to take the set to a pro for sn est. Good Luck
May 22, 2006 | Hitachi 36UX01S 36" TV
LG DU-42PX12XC 42 in. Plasma HDTV Logo
674 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
Ekse
