My door wont open or close but i hear the motor running i read in another post that it could be the gear stripped opened it up and the gear is stripped but when i push the button to open the gear wasn't turning so i wonder if the motor is shot?
Not much info here. Do you hear the motor running? If so, there are some plastic gears that strip out quite often. The door won't close if your photo sensors across the door are messed up. Look at the overhead motor, get the model #, get the manual from the net. I found manuals for many of them. They have trouble guides usually.
if you can hear the motoring running and nothing is moving then it is possible the internal gears are stripped. if motor does not run then it could be several electrical issues.
if you can hear the motor running but nothing is happening then the internal gears may be stripped. if the motor does not run then it is electrical and could be several things.
If you remove any gear that is coupling it to the motor you should be able to slide it back to where you want. I would put gear back just to hold it in place and keep it from moving. But you do have to replace that gearbox for future operation.
Remove the cover from the motor unit and you will find the drive gear is stripped. The part number is 41A2817 and is available at any good door service company.
Remove the cover from the motor unit and check the drive gear. Sounds like it is stripped. It is a white nylon gear just in front of the motor. It is available from any good door opener service company and comes with instructions. Now is a good time to also check the door springs.
The drive gear is stripped. Remove the cover and you can see it just in front of the motor. It is white nylon and the part number is 41A2817. Available from Sears or any good door opener service company. It will come with instructions.
