SOURCE: DIGITAL SOFTWARE UPDATES FOR SAMSUNG 32 INCH LCD TV
you cant force updates, and they may never be another update. updates are only made when there is a problem with the software in the tv
SOURCE: i updated my lcd samsung firm ware and the picture went crazy .
you need to go into the service menu and adjjust the option bytes. When you upgraged you changed them. The other solution would be to replace the main pcb
SOURCE: Describe your samsung ln40c530 will
This is more than likely from a capacitor failure in the power supply board. If you want to order the board yourself you can. If you want someone to fix it for you, take it into the shop after you call around for estimates. It is ALOT cheaper to take it in than to endure a trip charge.
SOURCE: I have a Samsung LCD
Hi.
To start, the firmware is not necessarily available. Firmware is available for download only when an update is released, or when there is a known firmware problem.
After that I wanted to say that firmware has nothing to do with faults given by power surges or bad weather electrical problems.
Pink/purple dots and startup problems are usually given by a defective PSU, sometimes by a defective main controller board. In fifteen years I have never seen a similar problem on Samsung LCD TVs being caused by Firmware.
I am sorry to hear that you recently carried a repair, but the bad weather has probably damaged the PSU components, and the part will probably need to be replaced or repaired. If problem is PSU the TV will also take longer than usual to start. The problem usually gets worsening after several days or weeks (takes longer to start).
The PSU is available from £35, the main board from £47. Usually replacing PSU is enough. The repair must be done by a trained person and the parts must be tested before replacement.
Here the parts for this set: le40a457c1dxxu'.
Regards.
Ginko.
