Kodak EasyShare V530 Digital Camera Logo
Posted on Dec 23, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need to get back to reset the date and time,
Level 3:
One Above All:
The expert with highest point at the last day of the past 12 weeks.
Top Expert:
  • Kodak Master 102,366 Answers
  • Posted on Jun 16, 2011
Kodak Master
Level 3:
One Above All:
Top Expert:
Answers
102366
Questions
0
Helped
10443331
Points
622693
Http://resources.kodak.com/support/shtml/en/manuals/urg00436/urg00436c4s12.shtml
Cannot reset time or date on ICF-CL75iP
Solution NO, Same problem YES! Our power was out for about 8 hours and now we cannot set the time or date! Surely someone has a solution! Please Help!
1helpful
Date and time wrong on start up
This indicates the BIOS battery is flat and therefore cannot store the correct date and time in the BIOS. You need to install a new BIOS battery and then go into the BIOS setup to set the Date & Time.
1helpful
Advent 5431 date keeps changing back to 2008
IS your TimeZone is Correct?
Right click on your clock, choose Adjust Date/Time.
Click Time Zone Tab. Make sure your Time zone is correctly set.
Boot into the BIOS (setup) screens and check the date and time there. If the date is off by years then that verifies you need a new CMOS battery. Do not confuse the CMOS battery with the large external battery you run the computer with.
Am using HP 8750 photosmart printer in east timor.I brought 344 cartridges for 97 which the vendor said its equivalent.How to replace cartridges with 344 for a old 97 cartridge.Settings required to change...
Easiest thing you can do to use old ink cartridges:
Move your system Date back to one year before the
Expiration Date(s) before clicking on [PRINT]
(Don't forget to reset the time back after your printing
is finished.)
If you need to print the same job multiple times, set
the date back, print to a File (instead of directly to the
printer), reset the date back and use CopyTo Printer
software to send the file(s) to your printer.
24helpful
Need to reset date and time after changing the
Here's the instructions on how to do that :
Quick Instructions on Setting the Date/Time:
  1. To set the current date and time, press and hold down the SET/EDIT button for a few seconds. Release the SET/EDIT button when the Month (M) and Day (D) indicators start flashing.
    Note: The unit will revert back to normal display if no other key is pressed for 10 seconds.
  2. While the Month (M) and Day (D) indicators are flashing press the LOCK button to cycle through the 3 available date formats.
  3. Once you have chosen an appropriate date format press the SHIFT button to switch between each of the different DATE, MONTH, YEAR, HOUR, and MINUTE fields. The field that is currently active will start flashing. To change the field's value press the LOCK button. Each stroke of the LOCK button moves one value up.
    Note: If you go past the current year, you will need to press the LOCK button to cycle through the year 2189 and back up to the current year.
  4. Once you are finished setting the Date and Time press the Set/Edit button to return to the normal display. The Date/Time Stamper is now ready to print.
The manual for this device can be found here :
http://images.cableorganizer.com/dymo-label-printer/DateMark_Time-Manual.pdf
13helpful
4answers
I need help to set the date and time
turn adding machine on. press reset button on back with pointy object. press the button picturing a calendar/clock. this will bring up the date. press & hold the "time set" button (same as M+/-) enter date on number pad. press time set to save. repeat for time
Batterie
Your internal CMOS battery(button battery) needs to be replaced. That keeps your date & time always working. Therefore when your main Battery runs out and external power is not present the date and time goes back to the date of manufacture.....sodeep
2answers
Reset my system back in time
You can use the system restore tool to reset your system back to a date in past. Which operating system are you using? Because only Windows ME and later operating systems(windows 2000, Windows XP and Windows Vista) have this option.
2helpful
3answers
Wrong date on the radio.
RESETTING THE CLOCK AFTER A TOTAL MEMORY LOSS
If you do not change the built in lithium battery within a reasonable period of time after you see the ‘flashing’ LOW BATT. warning indicator, the lithium battery may become exhausted and will no longer be able to supply back up power to the SmartSet internal computer.
If the unit is disconnected from the AC outlet after the battery is exhausted, or if a power interruption occurs, the SmartSet memory will be lost and the clock will need to be reset when the power is restored. Be sure to install a fresh lithium battery before you reset the clock, otherwise the clock will need to be reset each time the power is interrupted.
If the lithium battery is exhausted and you experience an interruption in the AC power supply, the clock will reset itself to its initial default setting when the power is restored.
The initial default setting is “12:00 AM, Saturday, January 1
(1 1), 2005”.
If you notice that the time on your SmartSet clock radio is completely incorrect, and the day indicator is also wrong, press the MONTH/DATE button to see the date. If the date display is showing “1 1” (January 1 ), you probably experienced
a total memory loss. To reset the clock after a total memory loss, proceed as follows:
1.) Install a new CR2430 lithium battery in the battery compartment.
2.) Connect the radio to your AC outlet and let the clock set itself.
3.) Depress the MONTH/DATE and TIME buttons together. The display will change from ‘time’ to ‘year’. While holding the MONTH/DATE and TIME buttons, press the UP button to
set the display to the correct year, then release the buttons.
4.) Depress the MONTH/DATE button. The display will change from ‘time’ to 'month/date’ (mm/dd). While holding the MONTH/DATE button, press the UP button to set the display
to the correct month and date. The Day indicator will change automatically as you adjust the month/date settings. When the correct month and date appear on the display, release the buttons.
5.) Depress the TIME button and the UP button to set the display to the correct time. Be sure to confirm that you have set the time correctly to ‘AM’ or ‘PM’ by observing the AM indicator.
6.) After you set the time, reconfirm that the Day, and Month/Date displays are still correct. Make final adjustments if necessary.
The SmartSet clock memory is now reset and the new lithium battery will maintain it for the next 5 to 8 years, depending on the number and duration of the power outages you experience.
IMPORTANT NOTE:
After resetting the clock, don’t forget to reset your wake up times, and alarm mode settings, and sleep timer settings as well.
Top Kodak Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Kodak Camera Expert? Answer questions, earn points and help others
