Question about Sony FD Trinitron WEGA KV-32FS120 32" TV
How to hook up a Sony Large Screen FD Trinitron WEGA stereo color TV (KV-36FS13) to a aiwa cx-na888
Posted by biguy7146 on
Eric Rotmil
  • 587 Answers
First of all i did fing the sony manual on sony's website http://www.docs.sony.com/release/KV36FS13.PDF
page 32 shows the audio out jacks , run the red and white wires to the inputs on the aiwa (i did not find a manual for the aiwa) if there are no input jacks on the aiwa then you can not connect it.
hope this helps
Thanks
Roety
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Posted on Dec 23, 2010
Adjust the vertical hold on my sony KV 36fs13
Look for a hole in the back of the TV that says vertical hold or it would be in the TV on the PCB. Just look for a small pot.
Dec 29, 2012 | Sony Fd Trinitron Wega Kv-36fs13 36" Crt...
Check and replace the CRT base connecting socket.
May 17, 2012 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony FD Trinitron WEGA KV-34HS420 34" TV Stand by
I have the indentical tv and problem. Cost to repair was about 250.
Aug 19, 2011 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony wega KV-36FS13 standby light blinking 5 times. no pic.
non of the blinks are good but here is yours
\5 times, Diagnosis: White balance failure (Not balanced) Possible causes: Video out (IC7101, 7201, 7301) is faulty (CR, CG, CB board), CRT drive (IC309) is faulty (A board), G2 is improperly adjusted. Symptoms of the problem: No raster is generated, CRT cathode current detection reference pulse output is small.
also not a DIY
Please rate my help++++Thankis for using FIXYA
May 19, 2010 | Sony FD Trinitron WEGA KV-36HS510 36" TV
No color on sony wega trinitron when hooked up to satellite, but plays movies in color
Try reprogaming your tv. And be sure you do not use a super video cord along side a yellow rca jack or components cords in the same aux. Check it out!
Nov 29, 2009 | Sony FD Trinitron WEGA KV-27FS120 27" TV
KV-36FS13
Your TV has problem in Tuner section hardware and its not so costly repair. Watching cable trough VCR is alternative solution, which you already have.
Aug 02, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony FD Trinitron Wega model KV-34BR800
Sony Wega Triniton KV-32FS100 TV
For the last week my TV has been going to a black screen for 10 seconds or so then the picture returns. It has been continual. Last night it stopped going to black screen, but now the standby light flashes 5 consecutive times and the color went haywire. A lot of red and everything that is suppose to be black is green.
I did a soft and hard reset with no success. What's wrong and is it worth fixing? Bought new in November 2002.
Aug 01, 2008 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Sony Trinitron KV - 36FS13 36" flatscreen
Hello MLD110368
I think, TV screen has white-balance failure thats why TV light blinks 5 times.
While living in Pakistan, I can't fix your TV there. In my point of view, it doesn't cost much and you should contact nearest Sony repair shop.
Apr 13, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony FD Trinitron WEGA KV-32FS120 32" TV Logo
191 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
