Televison & Video Logo
Posted on Dec 22, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I replaced the converegence chips on my Akai PT4298HD I can move the grid up and down but not left and right because not sure which buttons on my remote move it that way. The picture supplied of the one on this web site is for the samsung. My remote does not have all those buttons.
DILLIGAF
Level 3:
President:
  • Master 1,140 Answers
  • Posted on Dec 23, 2010
DILLIGAF
Master
Level 3:
President:
Answers
1140
Questions
Helped
681235
Points
4145
You should be able to use the number buttons on the remote to move the cursor to the correct crosshair:
2 = UP
4 = LEFT
6 = RIGHT.
8 = DOWN
After moving the cursor you can adjust the convergence as follows:
CHANNEL (CH) UP = UP
CHANNEL (CH) DOWN = DOWN
VOL+ = LEFT (?)
VOL- = RIGHT (?)
Not sure which way round it is for left and right but you'll find out as soon as you press one of the buttons.
Hope this helps. Please post back if you need further assistance.
Regards,
BElectric
1helpful
Akai pt4298hd 42 inch projection tv has red and green haze.part number stk392-040 were replaced 2 years ago.that fixed the problems.the symptons are the same.are these chips easy to acces ?
Yes they are But CK 2 resistors 2.7ohms in front of ICs if they are Bad they can cause same Problem to order new ICs $9.50 each Call Mats Electronics
1-800-628-1118
Tv out of focus
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
I have a 42'' where the color in the top left corner seems to have separated, or shifted. The picture is ghosted in red and green in this area. It happened all of a sudden.
Your TV most likely has a convergence failure. ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
Using your original remote go-to the tv settings then goto the convergence section.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
0667c5f.pngSOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
Akai
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
  • Screen looks 3D
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
Color separation Akai model pt4298HD
  • Screen looks 3D
Akai Convergence
If it is a fuse with no reading replace it ,What is the location number of part?For example F54 or does it have c45 or R66 ect..... You can E-mail me at [email protected]
Akai Convergence
What numbers are you using to move up AND down?
51MP392H/17 Blue convergence wont move not IC chip
You could have some opened resistors low ohms that are bad go back and ck them around convergence ics.
Double- Vision
More than likely your akai has defective stk392-040 Convergence chips . it also may have open resistors generally 3.9 ohm flame proff. this board is attached to the top left looking from the back of the set it is screwed on by 1 screw black in the center . after installation this will probably half to be converged dinamically. which means you will half to get to the grid this is done by using the remote press mute 183 quicly to enter numbers on thew remote 2 to adjust red 4 to adjust blue horizonta 6 to adjustred vertical and 8 to adjust red vertical using center button to go up and down
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
