The update process has corrupted the file system on the memory card inside the unit. To fix it you must format it. Connect it directly to a pc thru the USB cable - it will appear in My Computer as a Removable Media. Right click on them and select Format, then select FAT32 as the format. Wait for the process to end, Safely remove it then shut it down. wait one minute and start it over. It should either start normally or it will display an error message about the firmware - you will have to do the upgrade again.
And from now on ALWAYS wait until the "Now it's safe to disconnect" message appears on the screen and only then remove the cable.
In that case the corruption has affected even the firmware - the player is completely corrupted, it's practically dead. You will have to take it to an Apple shop, they will have to format the memory chip and reload the firmware at a hardware level, with tools that only they have.
Sorry, my bad, iRiver shop, not an Apple one - this isn't an actual iPod, it's an media player.
the advice that you gave me does not work. i connected it to pc via usb cable and it does not show up in my computer. message is still on ipod - internal, file system fail- format file system.
thanks ross.
i have an injured left hand, sorry for the lowercase typing, only using right hand
have you got my reply, errors still appears on ipod, your solution did not work, as ipod is frozen with error message and does not show up in my computer.
have message on iriver x20 screen Internal - file system fail - format file system.
got a response from an expert, but advice did not help.
Ipod does not show up in My Computer to reformat. have tried 2 cables in usb port. Ipod frozen with error message still. cannot do anything.
thanks for your advice.
just bad luck for me
i guess.
