Question about Leviton Decora Light Dimmer Switch
I just installed a Leviton IP106 Illumatech dimmer switch. It was replacing my existing rotary dimmer switch. The switch is a 3-way wiring job, with another 3-way toggle switch (no dimmer) on the other end of the room. The problem is: I can only turn the light on from the other toggle switch across the room. The "power" button on the new dimmer switch shows the lighted LED when the other switch is powered off, but when I try to turn the light on from the new dimmer, the button does nothing. However, when I turn the light fixture on from the other toggle switch across the room, I can then go over to the new dimmer switch and adjust the brightness with the slide...I just can't turn the light fixture on/off with the power button. I was sure to label all the wires and duplicate the connection from the old dimmer switch. Any ideas?
Posted by shani2020830 on
Bob
  • 565 Answers
The Leviton IP106 Illumatech dimmer switch must be installed at the switch location where the hot feed exists. From your description your hot feed is at the regular 3-way switch location. Swap locations.
Posted on Dec 22, 2010
Anonymous
I test electrical devices.
1. Many arrive defective.
2. Other electronic home devices don't workBuy inexpensive circuit analyzer from home center and see if there is a problem on the circuit.
3. I am looking at the IP106 manual for trouble spots.
Let me throw out a list of things that might help or not.
The other 3-way switch does NOT require additional jumper wire, as many devices do.
The other 3-way switch has 2 brass screws and 1 dark screw. Traveler wires connect to brass screws and these wires travel to dimmer and connect to dimmer red wires.
Here's a way to identify travelers for sure > replace dimmer with ordinary 3-way switch and put travelers on brass screws and check that both switches work in all positions.
One peculiar thing I see in manual is 3-D illustration for 3 way installation doesn't exactly match schematic drawing located beneath 3-D illustration. However I believe the red wires are the travelers based on directions given for 2-way installation.
Step 6 and step 7 show how to test dimmer immediately after wiring the device. And show minimum brightness adjustment. If your instructions don't have this section. Manuals have illustrations and manuals are shown at Leviton:
http://www.leviton.com/OA_HTML/ibeCCtpSctDspRte.jsp?section=17189&minisite=10025
http://www.leviton.com/OA_HTML/ibeCCtpItmDspRte.jsp?item=35337§ion=17189&minisite=10025
I see also that load maximum is 500 watts for 3-way. Check total wattage load.
The dimmer is for incandescent ... which implies that it will NOT work for CFLs or LED
The last part of manual has troubleshooting which does not show your issue, but gives a tech support number 1-800-824-3005
Add a comment and let me know what final outcome is, for my notes and to help the next fixya person who needs help.
I'M REPLACING AN OLD LEVITON ROTARY DIMMER WITH A LUTRON PADDLE DIMMER. THIS IS A 3-WAY SWITCH. THE ROTARY DIMMER HAS 2 BLACK WIRES, 1 RED, AND 1 GREEN. THE NEW DIMMER HAS 1 BLACK WIRE, 1 RED, 1...
with a three way switch like this, you will have two traveller wires and a common wire. Look in the instructions for the switch or on the back of the device itself to see if there is a wire labeled "common" or "com". This common wire from the old switch hooks up to the common wire on the new switch. I did a bit of searching on the leviton 6602, but couldn't find anything specifically about the three way version (I would venture to guess, however, that the red wire on the old switch is the common). The common on one of the three way switches will always be a constant hot (or power) wire...the common on the other three way switch will be the "switch leg" or the wire that connects directly to the light. The two travellers go to the other two wires. Check the pamplet that came with the lutron device, it should show which wire is common and which are travellers.
Sep 24, 2011 | Leviton Trimatron Rotary Dimmer 6602-i Lot...
My rotary dimmer doesn't switch 3-ways. I have to push the dimmer button to "on", then I can use the other switch to turn on/off.
You posted under Leviton rotary dimmer.
Lutron and Leviton have many 3-way dimmer styles, and both make 3-way rotary dimmers.
I remember years ago replacing 3-way switches with dimmers and having same experience as you. One dimmer has to be ON for the other dimmer to dim.
Later I learned when you replace both 3-way switches with dimmers, you buy a control-and-companion dimmer set. One dimmer is main, and it lets you dim from both locations. The two dimmers communicate with each other electronically. Buy these dimmers at lighting store that specializes in fixtures and dimmers. Ask for most experienced salesperson.
I checked to see if rotary dimmers are made in the companion set. And neither Leviton or Lutron show 3-way companion set rotary dimmers.
1) Leviton spec sheet on rotary 3-way dimmers does not show companion dimmer. This indicates that Leviton rotary dimmers don't have capability of communicating with each other.
2) Lutron has image of 3-way rotary dimmers.
Image shows single rotary dimmer in 3-way & 4-way circuit.
This tells me that Lutron does not have companion dimmer for 3-way rotary dimmer.
Nov 30, 2010 | Leviton Decora Rotary Dimmer 600-Watt SP...
The dimmer switch will turn on and off but wont dim the lights on a chandelier. model 6681-w. tried 2 different ones with the same results.
The Leviton 6681 is a push-button rotary-type incandescent dimmer with 600Watt capacity
If you have incandescent bulbs, the dimmer should work.
If the dimmer has different color wires, try reversing the wires.
If the dimmer replaced a 3-way switch, then this is not the right dimmer.
If you have compact florescent bulbs, you need a dimmer that also dims florescent.
http://www.google.com/products/catalog
Link shows the Leviton 6673 incandescent and florescent dimmer
But you also need dimmable compact florescent bulbs.
http://www.amazon.com/DIMMABLE-COMPACT-FLUORESCENT-LIGHT-SPIRAL/dp/B0014B84ZM
Oct 31, 2010 | Leviton #L11-06681-00I Ivory 600 Watt Push...
My girlfriend has a leviton illumatech IP106 that keeps "not working". after a number of months. It is operarting a standard dining room 6 light chandelier. A couple of her friends have replaced this in...
As a general rule for timers and dimmers:
The Black dimmer wire connects to black hot wire coming from breaker (122V line)
The red dimmer wire connects to Load (wire going to chandelier)
The wall red wire that is capped could be a couple different things. a) It could go to a second switch that was used to control the chandelier. b) it could be another wire that goes to same ceiling box as chandelier to be used to control a fan, except you don't have a fan. In the second case, if you install a fan with a light, you could control fan and light separately.
The green is a ground wire that connects to bare copper wire in box. The bare copper connect back to main breaker box on the Neutral busbar.
White wires that are twisted together inside your light switch box also connect back to to main breaker box on the Neutral busbar.
The ground wire and neutral are a redundant safety system to protect you from electrical devices and appliances that have 'shorted'
The black hot wire connects back to the circuit breaker.
For example, each circuit breaker controls one area of household lighting. The black white and copper wires leave breaker box in a single romex cable. The romex travels to a junction box in the area where the lights are located. The junction box is usually a switch box or a ceiling box. From the junction box, the romex travels to each other switch, light and receptacle box in the area. So each box has 1 hot and 1 neutral and 1 ground that is connected in a line that leads back to breaker box.
Here's a couple pages that make home wiring easier to understand:
http://waterheatertimer.org/See-inside-main-breaker-box.html
http://waterheatertimer.org/240-v-water-heater-circuit.html
http://waterheatertimer.org/Install-owb.html
Oct 15, 2010 | Leviton Decora Light Dimmer Switch
I hooked up the leviton IP106 dimmer switch for a single pole and when I test the it, switching it off and on it stays hot.
I'm assuming you've connected the line (hot) on the black and the load (out to fixture) to the red? So does the light stay on or your tester is measuring voltage. Some electronic controls will test voltage on a tester. if there is no load connected
Aug 03, 2010 | Leviton MFG L00-IPI06-1LM DIMMER SLIDE...
I have a black wire a white wire and a ground
The red wire is your chase wire and needs to go all the way to the other switch
Mar 07, 2010 | Leviton Rotary Dimmer 6683-i Ivory 3-way...
I have two wall switches in a hall for an over head light. I would like to install a rotary dimmer in one of the switches. My dimmer has 1 green and two black wires, and my wall switch has 2 black, 2 red...
You cannot, at least not using the dimmer you have in your hand. The switch with all the wires is a four-way switch, which is used to make a "suicided" 3-way switch. The power comes in AND goes out to the light from that switch. The other switch is a 3-way. Neither one has the "ON" or "OFF" marks on them, do they? You can buy a 3-way dimmer, but i do not know if rotary-style 3-way switches exist. You will have to install the dimmer at the other switch because i am quite certain no 4-way dimmers are available.
Nov 20, 2009 | Leviton Trimatron Rotary Dimmer 6602-i Lot...
Leviton Dimmer Switch wiring and ceiling wiring for new kitchen table light fixture
I recently purchased a Leviton Dimmer switch which has a brown lead. This switch is to replace 1 of 2, 3 way switches that control the ceiling light in my kitchen. My problem is the new dimmer switch has 4 leads including a brown one which has me confused. I have installed and replaced numerous dimmer switches without difficulty. Please help.
Oct 10, 2009 | Leviton Decora Light Dimmer Switch
I have a trimatron dimmer which has a black, red, green and another red wire labeled 3 way. My box has two black , white, red and groud wire. this room has two seperate light switches that control the...
When you take the existing switch out of the wall, the existing switch will have one black screw and two gold screws. The wire that is connected to the black screw of the existing switch (probably on of the black wires from the box) connects to the black wire on the new dimmer. The other two wires (one black and one red from the box) that are connected to the two gold screws on the existing switch will connect to the two red wires on the new dimmer. Basically, wire from black screw goes to new black wire and wires from gold screws go to new red wires.
Sep 27, 2009 | Leviton Trimatron Rotary Dimmer 6602-i Lot...
Install a single pole light dimmer
House wires are for a 3 way switch, you will need a different switch
Jan 31, 2009 | Leviton Trimatron Rotary Dimmer 6602-i Lot...
Leviton  Decora Light Dimmer Switch Logo
711 people viewed this question
Top Leviton Electrical Supplies Experts
Gene Haynes
Marvin
Marvin
john h
Are you a Leviton Electrical Supply Expert? Answer questions, earn points and help others
