Sharp AR208D Copier Logo
Anonymous Posted on Dec 22, 2010
Our copier is an AR-208D & it has a error code of H4-00 displayed. Can we fix it?
Anonymous
Level 3:
  • Master 1,110 Answers
  • Posted on Dec 22, 2010
Anonymous
Master
Level 3:
Answers
1110
Questions
Helped
544588
Points
4088
In most cases the flashing H4 or H then 4 code on these machines is caused by voltage fluctuations or surges. Normally there is nothing wrong with the machine and the code is easily reset. Here is the procedure:
Press the following key's in sequence and as quickly as possible (with 4 seconds for the first 4 keys)
Press "#" then the " * " (star) key then the "Clear" key then the " * " key again.
So in other words #, star, C, Star
If done correctly the display should go blank.
Then key in 14 as if you were going to make 14 copies.
Now press the "print" button
The machine should automatically shut down and restart with the H4 code being gone.
If the H4 code comes back after reset then in this case you have a fusing unit problem and will need to have the unit serviced.
Good Luck and Thank You for using Fixya.
WheatlandServices
Testimonial: "You are the best!!! Thank you it works & the very 1st time I tried & I really appreciate your help. Thanks"
1helpful
Error Code F2 - 64 of photocopier Sharp AR 5816s
If you have the install disc , Go into remove programs and uninstall it . then reinstall it . up date as there may be a new driver for it.
HOW TO FIND THE IP ADRESS OF MY COPIER
The 208D had a network module on the back of it where the Cat5 cable plugs in. there is a little black button on there, if you hold it down it will print out the network config page.
Copier Collin Houston TX Copier and Imaging Expert
HOW TO REPLACE THE PRINT DRUM ON A SHARP AR-208D COPIER
  1. fold down the bypass tray on the right
  2. hit grey button on right door to open it
  3. fold the front cover down
  4. press green button to remove the toner
  5. the drum is the other thing you can grab and there and remove.
  6. reassemble in reverse order of 5-1
2answers
Sharp ARM207
try typing the error code into a search engine.
1helpful
Need to know how to add developer power to a sharp ar-208d. my copies are all coming out blank
No need developer.When your machine need developer,it show developer signal.blank page print means,charger problem please check corona wear may be it broken or displace.
How add developer to sharp ar-208d
Set-up for this copier sure isn't well-documented. We just got ours working today, by following the instructions here: https://www.businessneedz.com/Manuals/ar168s_setup.pdf (yes, it lists a different model number, but the instructions worked, and were linked from the ar-208d product page from the supplier)
Sharp AR-208D copier needs developer - how to add?
Set-up for this copier sure isn't well-documented. We just got ours working today, found out how to add the toner by following the instructions here: https://www.businessneedz.com/Manuals/ar168s_setup.pdf (yes, it lists a different model number, but the instructions worked, and were linked from the ar-208d product page from the supplier)
10helpful
4answers
Error: Printing data is inaccurate, printing processing is stopped Printer error page is printed with this error prints fine from the webpage printer is installed on windows 2000 over a network
I got the same error with another type of sharp photocopier AR-M257
My error, I was installing the wrong driver.
I installed the Sharp driver with the PS at the end.
You can download from here depending the version of the Windows you have
http://www.sharpusa.com/products/business/copiers/business_copiers_drivers/
Good luck!!
Top Sharp Office Equipment & Supplies Experts
k24674
ZJ Limited
ZJ Limited
Norman Weimar
Norman Weimar
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
